[REL] Swap or Copy Fields 1.0
Scambia il primo campo scelto col secondo oppure copia il primo campo nel secondo.
Solo per campi stringa modificabili.
Per utilizzare su molti dati, consiglio un backup precedente.
:rolleyes: :shaking: :shocked: :wow:
Uniquement pour champs caractères et modifiables
Only string fields and modifiable.
Swaps or copy from first field to second field choosed.
Authors=Fulvio53s03 da scorpion7552
Title=SwapCopyFields
Description=inverse/copie 2 champs/ swaps/copy 2 fields
Site=
Language=EN,FR
Version=1.0
Requires=3.5.0
Comments=Uniquement des champs caractères et modifiables|Only string fields and modifiable. Swaps or copy from first field to second field choosed.
GetInfo=0
RequiresMovies=1
Mode=1|0|0=swap fields mode|1=copy fields mode)
[Parameters]
program SwapFields;
	CopyMode: Integer;
	str1, str2, abort: string;
	fld1, fld2: integer;
// creates fields list and returns the selected field number
function SelectField :integer;
	fld: string;
	if fld1 = 0 then
		PickTreeAdd('Sélectionner le 1er champ/Select 1st field', '')
		PickTreeAdd('Sélectionner le 2ème champ/Select 2nd field', '');
// create list (string fields only)
	AddFieldToList(fieldMedia, 'Label/Etichetta');
	AddFieldToList(fieldMediaType, 'Tipo');
	AddFieldToList(fieldSource, 'Source/Origine');
	AddFieldToList(fieldBorrower, 'Borrower');
	AddFieldToList(fieldOriginalTitle, 'Titre original/Original Title');
	AddFieldToList(fieldTranslatedTitle, 'Titre Traduit/Translated Title');
	AddFieldToList(fieldDirector, 'Réalisateur/Director');
	AddFieldToList(fieldProducer, 'Producteur/Producer');
	AddFieldToList(fieldCountry, 'Pays/Country');
	AddFieldToList(fieldCategory, 'Catégorie/Category');
	AddFieldToList(fieldActors, 'Acteurs/Actors');
	AddFieldToList(fieldUrl, 'Adresse  Web/URL');
	AddFieldToList(fieldDescription, 'Description');
	AddFieldToList(fieldComments, 'Commentaires/Comments');
	AddFieldToList(fieldMediaType, 'Media Type');
	AddFieldToList(FieldFilePath, 'File Path');
	AddFieldToList(FieldVideoFormat, 'Video Format');
	AddFieldToList(FieldCertification, 'Certification');
	AddFieldToList(FieldAudioFormat, 'Audio Format');
	PickTreeExec(fld);
	result := StrToInt(fld,0);
// add a field to the selection list
// AddFieldToList(fieldnumber, text_for_display);
procedure AddFieldToList(fldn: integer; str:string);
// if fieldnumber is not equal to fld1 (1st selected field) and is modifiable
	if (fldn <> fld1) and CanSetField(fldn) then
		PickTreeAdd(str, IntToStr(fldn));
//  start here
	if abort = 'o' then                             // selection has been canceled
	if fld1 = 0 then                          // first time: select fields to swap
// note: number = 0 = fieldNumber: not selectable here
	if not CheckVersion(3,5,0) then
			abort := 'o';
      		CopyMode := GetOption('Mode');
		fld1 := SelectField;
		if fld1 <> 0 then
			fld2 := SelectField;
  	if CopyMode = 0 then ShowMessage('N.B. you are going to swap first field with the second');
  	if CopyMode = 1 then ShowMessage('N.B. you are going to copy first field  to  the second');
		if (fld1 = 0) or (fld2 = 0) then
			abort := 'o';                                              // no selection
// swap/copy these two fields for the current item
	str1 := GetField(fld1);
  str2 := GetField(fld2);
	SetField(fld2, str1);
	if CopyMode = 0 then SetField(fld1, str2);
Sorry for my delay :ha: .
Now it should be OK! :hihi:
