a tvtome script for all episodes (one series) at once
cortexwave
Post by cortexwave »
hi,
is it possible to (and could someone) write a script fot tvtome which at once imports a whole series? if i is possible it would be great if someone could make such a script .....
thank you very much ... and i hope that it is possible.
cortexwave
For the moment the scripting engine cannot add movies in the list. So even if somebody makes a script for that you will first have to create an empty list of movies, with at least the number of the episodes (or something else to identify them).
cortexwave
hi antp,
will it be possible in the future?
thanks
cortexwave
Sure, I have to add a script mode where the script can jump itself to the next movie, or add movies.
It would be quite easy, so it will probably be done in 4.0 ;)
cortexwave
cool thank you
cortexwave
