Import with camprison
SiburNY
Post by SiburNY »
Hi.
I use usualy query 2 sources to get info about movie.
It would be great to have one window, where you can run two different scripts and see result on one window in different columns. And then, between columns you can have something similar to checkboxes, so you have choice between columns on every field.
Antp, what you think ? :)
hmmm... I do not know... it may be nice yes, but maybe also a little difficult to do.
We'll see that later ;)
SiburNY
Post by SiburNY »
Yeah, I understand that's a little bit hard to implement. But I like idea :). Maybe we'll save for AMC V :grinking:
