BUG: HelpFile Version 02/03/2003
Ruffus2000
Post by Ruffus2000 »
It is not a Bug, but some Informations are missing.
In Section Technical Information -> Catalog File Format
in the Header there is some Information missing!
OwnerDescription:        array of char;
MfG
Ruffus2000
What is missing ?
If you mean that it does not compile, it is normal. As explained at the top of the page, when I wrote "array of char" it means an Integer with the length followed by the characters. In Delphi you can store that in a string, but do not forget to make a SetLength before reading the data to the string.
Ruffus2000
Sorry, i explain it.
Your Help File says:
Headers :
strFileHeader33 = ' AMC_3.3 Ant Movie Catalog 3.3.x   www.buypin.com  www.ant.be.tf ';
OwnerName:        array of char;
OwnerICQ:         array of char;
OwnerSite:        array of char;
OwnerMail:        array of char;
i think it should be
Headers :
ok, thanks for the info ;)
