New script for import large image from dvdnet.ru (Ðóññêèé)
Dmitry501
Post by Dmitry501 »
It is a new script for import of the big pictures of covers with dvdnet.ru. It is based on a script written Kamik. Please, write remarks.
// GETINFO SCRIPTING
// Imports big picture from DVDnet.ru
 *  For use with Ant Movie Catalog 3.4.2           		*
 *  www.ant.be.tf/moviecatalog ··· www.buypin.com  	*
 *  It is based on a script written Kamik aka SlawDD	*
program DVDnet_PICT;
  BaseAddress = 'http://www.dvdnet.ru/';
  MovieName2: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
procedure AddMoviesTitlesDVD(Page: TStringList; var LineNr: Integer);
  StartPos, EndPos: Integer;
  LineNr := FindLine('<b>ÔÈËÜÌÛ (æàíð è àêò¸ðû, èãðàþùèå ãëàâíûå ðîëè):</b><br>', Page, 0);
     WHILE pos('<a href="index', Line)>0 DO
     BEGIN
       StartPos := pos('<a href="index', Line) + 9;
       MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
       MovieTitle := copy(Line, StartPos, pos('</i>', Line) - StartPos);
       Delete(Line, 1, pos(' </a><br><', Line));
       HTMLDecode(Movietitle);
       HTMLRemoveTags(MovieTitle);
       PickTreeAdd(MovieTitle, BaseAddress + MovieAddress);
    LineNr := LineNr + 1;
  until (pos('<b>ÌÓËÜÒÔÈËÜÌÛ:</b><br>', Line)>0) or (pos('</table>', Line)>0);
procedure AddAnimeTitlesDVD(Page: TStringList; var LineNr: Integer);
  LineNr := FindLine('<b>ÌÓËÜÒÔÈËÜÌÛ:</b><br>', Page, 0);
  until (pos('</table>', Line)>0);
procedure AddPictureDVD(Page: TStringList);
  Line, Value : string;
  LineNr, BeginPos, EndPos: Integer;
 // Get Picture
  LineNr := FindLine('window.open("pict', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('"pict', Line);
    Delete(Line, 1, BeginPos);
    EndPos := pos('"', Line);
    Value := BaseAddress + copy(Line, 1, EndPos - 1);
    GetPicture(Value, True); // False = do not store picture externally ; store it in the catalog file
  LineNr, StartPos, EndPos, L: Integer;
  MovieAddress, FindMovieName : string;
  if (pos('Ïî âàøåìó çàïðîñó â áàçå íàéäåíî:', Page.Text)>0) then
        PickTreeAdd('Íàéäåíî íà www.dvdnet.ru', '');
        if LineNr >-1 then
            PickTreeAdd('Ôèëüìû', '');
            AddMoviesTitlesDVD(Page, LineNr);
        if LineNr > -1 then
            PickTreeAdd('Ìóëüòôèëüìû', '');
            AddAnimeTitlesDVD(Page, LineNr);
            AddPictureDVD(Page);
  DisplayResults;
  PickListClear;
  if CheckVersion(3,4,0) then
    if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
    if Input('Import picture from DVDNet.ru', 'Enter the title of the movie:', MovieName) then
      MovieName2:=MovieName;
      MovieName:=StringReplace(MovieName, '’', Chr(39));
			MovieName:=AnsiLowerCase(MovieName);
			MovieName:=AnsiUpFirstLetter(MovieName);
			if pos('The ', MovieName)=1 then MovieName:=StringReplace(MovieName, 'The ', '');
			AnalyzePage('http://www.dvdnet.ru/index.php?p=9&searching=y&checkform=y&search='+UrlEncode(MovieName));
It seems that there are lots of new scripts from you
Dmitry501
Post by Dmitry501 »
thanks
I have written a little... :)
Скажите Дмитрий, а у Вас нет версии этого скрипта, что-бы с 'http://www.dvdnet.ru/' скачивать всю инфу, а не только увеличенную картинку?
Please write in English, not in HTML Entities :hihi:
wheelyy69
Post by wheelyy69 »
PTDR :lol: :lol: :lol:
Is it a russian keyboard ?
Dmitry501
Post by Dmitry501 »
:lol:(Íàïèøè íîðìàëüíî!)
SiburNY
Post by SiburNY »
It was in russian, because script is for russian web-site.
He intended to say following:
Ñêàæèòå Äìèòðèé, à ó Âàñ íåò âåðñèè ýòîãî ñêðèïòà, ÷òî-áû ñ 'http://www.dvdnet.ru/' ñêà÷èâàòü âñþ èíôó, à íå òîëüêî óâåëè÷åííóþ êàðòèíêó?
Ìåíÿ ýòî òîæå èíòåðåñóåò ;)
Well, for me it does not change anything :D I see "random" accentuated characters (since I use west-european characters set)
Dmitry501
Post by Dmitry501 »
to SiburNY:
Íåò, íî åñëè òåáå î÷åíü íóæíî, òî ìîãó íàïèñàòü...
No but if it is very necessary for you I can write...
SiburNY
Post by SiburNY »
Dmitry501 wrote:to SiburNY:
Rus: ß íå ãîðþ, ïðîñòî åñëè åñòü âñå â îäíîì, òî ïî÷åìó áû íå ïîëüçîâàòü :). À åñëè íåòó, òîãäà íå òðàòü âðåìÿ :). Ïàñèáà âñå ðàâíî.
Eng: I'm not desperate to have it, but if you have written already, I don't mind having all-in-one script :). If you haven't, so don't bother yourself :). Thanks anyway.
Dmitry501
Post by Dmitry501 »
Rus: ß íå ãîðþ, ïðîñòî åñëè åñòü âñå â îäíîì, òî ïî÷åìó áû íå ïîëüçîâàòü . À åñëè íåòó, òîãäà íå òðàòü âðåìÿ . Ïàñèáà âñå ðàâíî.
Eng: I'm not desperate to have it, but if you have written already, I don't mind having all-in-one script . If you haven't, so don't bother yourself . Thanks anyway.
RUS: Ó ìåíÿ åñòü áîëüøîé ñêðèïò Kamika êîòîðûé ïîëó÷àåò èíôîðìàöèþ èç dvd.net, movieguide.ru, soyuz.ru. ß èç íåãî âûäåðíóë ÷àñòü, êîòîðàÿ çàãðóæàåò êàðòèíêè. Ñàìè îïèñàíèÿ ÿ çàãðóæàþ èç ñêðèïòà sharereactor.ru, dvdspecial.ru, videoguide.ru À âîò áîëüøèå êàðòèíêè ëó÷øå âñåãî íà dvdnet.ru...
Çàâòðà îïóáëèêóþ ñêðèïò, êîòîðûé èìïîðòèðóåò âñþ èíôó èç dvd.net
ENG: I have big script Kamika which receives the information from dvd.net, movieguide.ru, soyuz.ru. I from him have pulled out a part which loads a picture. I load descriptions from a script sharereactor.ru, dvdspecial.ru, videoguide.ru And big a picture in the best way on dvdnet.ru...
Tomorrow I shall publish a script which imports all info from dvd.net
SiburNY
Post by SiburNY »
Rus: Òîãäà ñóïåð :) ß ñ óäîâîëüñòâèåì ïîòåñòèðóþ è ïîòîì ïîïîëüçóþ :). Ïàñèáà.
Eng: That's cool :) I would love to test it and thet to use it :). Thanks.
timmy
Post by timmy »
This script seems to only import movie name for me.... Doesnt import any covers ;/
