Culturalia+IMDB (Batch) Script, Latest Version
folgui
Post by folgui »
Hello!
New script to import several movies in batch mode, mixing culturalia+imdb.
It's a first release that works Ok, i think. Try it and tell me any bugs and
enchancements.
THE LATEST SCRIPT:
// SCRIPTING
// Culturalia+IMDB (Batch) v1.0
 *  Script merged by Jose Miguel Folgueira, based  *
 *  on a similar script merged by Antoine Potten   *
 *    Culturalia, http://www.culturalianet.com     *
 *  Original version made by David Arenillas       *
 *  New version made by Antoine Potten             *
 *  Contributors:                                  *
 *    Jose Miguel Folgueira                        *
 *    RedDwarf                                     *
 *    Hades666                                     *
 *    KaBeCi                                       *
 *    PolloPolea                                   *
 *    Moises Déniz                                 *
 *    Val                                          *
 *  Thanks to Culturalia's webmaster for his help  *
 *  and for providing more direct access to his    *
 *  database                                       *
 *      IMDB (US), http://us.imdb.com              *
 *  (c) 2002-2004 Antoine Potten                   *
 *                          software@antp.be       *
*  TransformTitle function from IMDB (US) Script   *
 *  Contributors :                                 *
 *    Danny Falkov                                 *
 *    Kai Blankenhorn                              *
 *    lboregard                                    *
 *    Ork <ork@everydayangels.net>                 *
 *    Trekkie <Asimov@hotmail.com>                 *
 *    Youri Heijnen                                *
 *  For use with Ant Movie Catalog 3.4.x           *
 *  www.antp.be/software/moviecatalog              *
 *  This program is free software; you can         *
 *  redistribute it and/or modify it under the     *
 *  terms of the GNU General Public License as     *
 *  published by the Free Software Foundation;     *
 *  either version 2 of the License, or (at your   *
 *  option) any later version.                     *
program Culturalia_IMDb_Batch;
  BaseURLCulturalia = 'http://www.culturalianet.com/bus/catalogo.php';
  UseLongestDescIMDB = False; // If set to False shortest description available will be imported, faster since taken from main page
  // Set the following constants to True to import field, or False to skip field (fiels to import from IMDB). By default, only the fields not available at  Culturalia are set to True.
  // Pon las siguientes constantes a True para importar campo o False para no hacerlo (campos a importar de IMDB). Por defecto, sólo los campos no disponibles en Culturalia están a True.
  ImportActors = False;
  ImportCategory = False;
  ImportComments = False;
  ImportCountry = False;
  ImportDescription = False;
  ImportDirector = False;
  ImportLength = True;
  ImportLanguage = False;
  ImportOriginalTitle = False;
  ImportTranslatedTitle = False;
  LeaveOriginalTitle = True; // True will get Translated Title, yet Original Title field will remain same
  ImportPicture = False;
  ImportLargePicture = False; // If set to False small pic will be imported
  ImportRating = True;
  ImportURL = False;
  ImportYear = False;
  TitleMixedCase = False; // If true, each letter of each word of title begins with Uppercase. If false, the script transforms the titles in lowercase except first word
  ExternalPictures = False;
    { True: Pictures will be stored as external files in the folder of the
            catalog
      False: Pictures will be stored inside the catalog (only for .amc files) }
  ManualPictureSelect = False;
    { True: If no Title Match found a picture selection window appears
      False: Revert to IMDB picture }
  // Donde vamos a buscar en el caso de no haber introducido ni el título original ni el traducido en los campos correspondientes, sino en la ventana que
  // se abre y nos lo solicita.
  // 1-Titulo traducido, 2-Titulo original, 3-General
  // What type of search in case we don't write the original title nor traslated one in the corresponding fields, we do it in the input box.
  // 1-Translated title, 2-Original Title, 3-General
  defdonde='1';
  MovieName, Titulo: string;
  MovieURL: string;
  tmp: string;
  donde: string;
  Articles: array of string;
  Index: Integer;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
procedure AnalyzePageIMDB(Address: string);
  MovieURL: string;
  if pos('<title>IMDb', Page.Text) = 0 then
    AnalyzeMoviePageIMDB(Page)
    MovieURL := AddMoviesTitles(Page, '<b>Exact Matches</b>');
    if MovieURL = '' then
      MovieURL := AddMoviesTitles(Page, '<b>Partial Matches</b>');
      MovieURL := AddMoviesTitles(Page, '<b>Approximate Matches</b>');
    if MovieURL <> '' then
      AnalyzePageIMDB(MovieURL);
function FindValue(BeginTag, EndTag: string; Page: TStringList; var LineNr: Integer; var Line: string): string;
  BeginPos, EndPos: Integer;
  Value: string;
  Result := '';
  Value := '';
  BeginPos := Pos(BeginTag, Line);
  if BeginPos > 0 then
    BeginPos := BeginPos + Length(BeginTag);
    if BeginTag = EndTag then
      Delete(Line,1,BeginPos-1);
      BeginPos := 1;
    EndPos := pos(EndTag, Line);
    while ((EndPos = 0) and (LineNr < Page.Count-1 )) do
      Value := Value + copy(Line, BeginPos, Length(Line) - BeginPos);
      // Next Line
      BeginPos := 1;
      LineNr := LineNr + 1;
      if Value = '' then
        Exit;
      EndPos := Pos(EndTag, Line);
  Result := Value;
procedure AnalyzeMoviePageIMDB(Page: TStringList);
  Line, Value, Value2, FullValue, OldOriginalTitle: string;
  LineNr, Desc, i: Integer;
  OldTitleParts, AllTitles: TStringList;
  LongDescr: Boolean;
  LongDescr := UseLongestDescIMDB;
  if (LongDescr) and (Pos('<a href="plotsummary">', Page.Text) = 0) then
    LongDescr := False;
  MovieURL := 'http://imdb.com/title/tt' + Copy(Page.Text, Pos('?pending&add=', Page.Text) + 17, 7);
  // URL
  if ImportURL then
    SetField(fieldURL, MovieURL);
  AllTitles := TStringList.Create;
  // Original Title & Year
  if (ImportOriginalTitle) or (ImportYear) then
    if LineNr > -1 then
      BeginPos := pos('<title>', Line);
        BeginPos := BeginPos + 7;
      EndPos := pos('(', Line);
      if EndPos = 0 then
        EndPos := Length(Line);
      HTMLDecode(Value);
      if ImportOriginalTitle then
        OldOriginalTitle := GetField(fieldOriginalTitle);
      if (ImportTranslatedTitle) and not (LeaveOriginalTitle) then
        EndPos := Pos('/I', Line);
        if EndPos < BeginPos then
          EndPos := pos(')', Line);
        if ImportYear then
          SetField(fieldYear, Value);
  // Translated Title
  if ImportTranslatedTitle then
    OldTitleParts := TStringList.Create;
    // Tokenize OldOriginalTitle while removing certain chars/common words ("the", "of")
    Value := AnsiUpperCase(OldOriginalTitle);
    Value := StringReplace(StringReplace(Value, ',', ' '), ':', ' ');
    Value := StringReplace(StringReplace(Value, '(', ' '), ')', ' ');
    Value := StringReplace(StringReplace(Value, 'OF', ' '), 'THE', ' ');
    until Pos('  ', Value) = 0;
    Value := StringReplace(Trim(Value), ' ', ',');
    // Value now contains the original title (comma-separated) that was filled in before running the script
    Value2 := '';
    for i := 1 to Length(Value) do
      if Pos(',', Copy(Value, i, 1)) = 0 then
        Value2 := Value2 + Copy(Value, i, 1);
      if (Pos(',', Copy(Value, i, 1)) = 1) or (i = Length(Value)) then
        OldTitleParts.Add(Value2); // put each comma-separated value from Value into a separate string in TitleParts
        Value2 := '';
    for i := 0 to OldTitleParts.Count - 1 do
    // Begin comparing title parts (from the title originally filled in by moviedb owner) with
    // the 'true' Original Title (extracted from IMDb) to see if it's a foreign title and needs a Translated Title
      if Pos(OldTitleParts.GetString(i), AnsiUpperCase(GetField(fieldOriginalTitle))) <= 0 then
      begin // no match, must be a foreign title
        LineNr := FindLine('Also Known As', Page, 0);
        if LineNr > -1 then
          if Pos('Also Known As', Line) > 0 then
            BeginPos := Pos('Also Known As', Line) + 26;
            Value := Copy(Line, BeginPos, Length(Line) - BeginPos - 4);
            Value := StringReplace(Value, '<br>', '/ ');
            HTMLDecode(Value);
            SetField(fieldTranslatedTitle, Trim(Value));
    OldTitleParts.Free;
  // Rating
  if ImportRating then
    if LineNr > -1 then
      if Pos('/10', Line) > 0 then
        SetField(fieldRating, Value);
  // Language
  LineNr := FindLine('Language:', Page, 0);
  if LineNr > -1 then
    EndPos := pos('</a>', Line);
    if EndPos = 0 then
    if ImportLanguage then
  if ImportPicture then
    GetMoviePicture(Value, Page, AllTitles);
  AllTitles.Free;
  // Director
  if ImportDirector then
    if LineNr > -1 then
      FullValue := '';
          if FullValue <> '' then
        Delete(Line, 1, EndPos);
      until Pos('</a>', Line) = 0;
      HTMLDecode(FullValue);
  // Actors
  if ImportActors then
    LineNr := FindLine('ast overview', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('redited cast', Page, 0);
    if LineNr > -1 then
      FullValue := '';
        BeginPos := Pos('<td valign="top">', Line);
          Delete(Line, 1, BeginPos);
          if EndPos = 0 then
            EndPos := Pos('</td>', Line);
            BeginPos := pos('.... </td><td valign="top">', Line);
              EndPos := pos('</td></tr>', Line);
              BeginPos := BeginPos + 27;
              if Value2 <> '' then
                Value := Value + ' (as ' + Value2 + ')';
          Line := '';
      until Line = '';
  // Country
  if ImportCountry then
    LineNr := FindLine('Country:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
  if ImportCategory then
    LineNr := FindLine('Genre:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  //Description
  if ImportDescription then
    LineNr := FindLine('Plot Summary:', Page, 0);
    if LineNr < 1 then
      LineNr := FindLine('Plot Outline:', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('</b>', Line) + 5;
      EndPos := pos('<a href="/rg/', Line);
      if EndPos < 1 then
        if EndPos < 1 then
          EndPos := pos('<br><br>', Line);
        if EndPos < 1 then
      HTMLDecode(Value);
      HTMLRemoveTags(Value);
      if UseLongestDescIMDB then
        SetField(fieldDescription, GetDescriptions(MovieURL + 'plotsummary'))
  // Comments
  if ImportComments then
    LineNr := FindLine('<b>Summary:</b>', Page, 0);
    if LineNr > -1 then
      Value := '';
        EndPos := Pos('</blockquote>', Line);
        if EndPos = 0 then
          EndPos := EndPos - 1;
        Value := Value + Copy(Line, 1, EndPos) + ' ';
      until Pos('</blockquote>', Line) > 0;
      HTMLDecode(Value);
      Value := StringReplace(Value, #13#10+' ', #13#10);
  // Length
  if ImportLength then
    LineNr := FindLine('Runtime:', Page, 0);
    if LineNr > -1 then
      EndPos := pos(' min', Line);
      if EndPos = 0 then
        EndPos := pos('  /', Line);
      if EndPos = 0 then
      if Pos(':', Line) < EndPos then
        BeginPos := Pos(':', Line) + 1
        BeginPos := 1;
      SetField(fieldLength, Value);
  DisplayResults;
procedure GetMoviePicture(Language: string; Page, AllTitles: TStringList);
  Line, Value, Value2, Aka, PictureAddress: string;
  AmazonPage: TStringList;
  FoundOnAmazon, PickTreeSelected, PictureAvailable: Boolean;
  TitleRef, ImgRef, NoImage: string;
  LineNr, BeginPos, EndPos, PickTreeCount, ParagraphIndex, Index, TitleLine, LastMatch: Integer;
  FoundOnAmazon := False;
  if ImportLargePicture then
    // Find Alternate Titles for Movies which are not in English
    Aka := '';
    if Language <> 'English' Then
      LineNr:= FindLine('Also Known As',Page,0);
      EndPos:=0;
      if LineNr > -1 then
          Aka:=FindValue('<br>','<br>',Page,LineNr,Line);
          if Aka <> '' then
            BeginPos:=1;
            EndPos:=Pos('(',Line);
            if EndPos = 0 then
              EndPos := Length(Aka);
            Value := copy(Aka, BeginPos, EndPos - BeginPos - 1);
            Value:=TransFormIMDBTitle(Value);
            AllTitles.Add(Value);
        until (Pos('</td>', Line) > 0) or (Pos('Runtime', Line) > 0) or (Pos('MPAA', Line) > 0 ) or (Pos('Country', Line) > 0) or (Pos('Certification', Line) > 0);
    TitleRef:='dvd>';
    ImgRef:='dvd><img';
    NoImage:='/icons/dvd-no-image.gif';
    LineNr := FindLine('title="DVD available at Amazon.com"', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('title="VHS available at Amazon.com"', Page, 0);
      if LineNr > -1 then
        TitleRef:='video>';
        ImgRef:='video><img';
        NoImage:='/icons/video-no-image.gif';
    if LineNr > -1 then
      if(TitleRef='dvd>') then
        EndPos := pos('title="DVD', Line);
        BeginPos := pos('title="VHS', Line);
        while (BeginPos > 0) and (BeginPos<EndPos) do
          Delete(Line, 1, BeginPos+1);
      BeginPos := Pos('href="', Line) + 5;
      EndPos := Pos('"', Line);
      AmazonPage := TStringList.Create;
      AmazonPage.Text := GetPage('http://us.imdb.com' + Value);
      // Original Title
      Value2 := AllTitles.GetString(0);
      Value2 := TransFormIMDBTitle(Value2);
      PickTreeCount := 0;
      PickTreeAdd('Available Titles for matching a picture to: ' + Value2, '');
      ParagraphIndex := 1;
      LineNr := 0;
      LastMatch := -1;
      TitleLine := -1;
        LineNr := FindLine('<b>'+IntToStr(ParagraphIndex)+'.', AmazonPage, LineNr);
        if LineNr > -1 then
          TitleLine:=LineNr;
          Value:='';
          PictureAvailable:=False;
            TitleLine:=TitleLine +1;
            Line:= AmazonPage.GetString(TitleLine);
            BeginPos:=0;
            if Pos(TitleRef,Line) > 0 then
              if Pos(ImgRef,Line) = 0 then
                for Index:=0 to AllTitles.Count -1 do
                  Value2:=AllTitles.GetString(Index);
                  BeginPos:=Pos(Value2,Line);
                // Match not found
                if BeginPos = 0 then
                  BeginPos:=Pos(TitleRef,Line)+Length(TitleRef);
                  EndPos:=Pos('</a>',Line);
                  Value:=Copy(Line,BeginPos,EndPos-BeginPos);
                PictureAvailable:=(Pos(NoImage,Line) = 0);
                PictureAddress:=IntToStr(TitleLine);
          until (Pos('</table>',Line ) > 0);
          // Try to Find a Title Match
          if Pos(Value2,Line) > 0 then
            // Compare Current Title to Original
            BeginPos := Pos(TitleRef, Line) + Length(TitleRef) -1;
            EndPos:= Pos('(',Line);
            if EndPos = 0 Then
              EndPos := Pos('</a>', Line);
            Value:= Trim(Value);
            if Value = Value2 then
              if PictureAvailable then
                LastMatch:=LineNr;
                //Break
            PickTreeAdd(Value,PictureAddress);
            PickTreeCount:=PickTreeCount+1;
        ParagraphIndex:=ParagraphIndex+1;
      until (LineNr = -1);
      LineNr:=LastMatch;
      if (LineNr = -1) then
        // Handle Amazon Page Redirection(s)
        LineNr:= FindLine('You clicked on this item',AmazonPage,0);
          LineNr:=FindLine('Customers who bought',AmazonPage,0);
        // Display the Picture Selection Window
        if (LineNr = -1) and ManualPictureSelect and (PickTreeCount > 0) then
          PickTreeSelected:=PickTreeExec(PictureAddress);
          if PickTreeSelected then
            LineNr:=StrToInt(PictureAddress,0);
        if (LineNr > -1 ) then
          LineNr := FindLine('src="http://images.amazon.com/images/P/',AmazonPage, LineNr);
          if not PickTreeSelected then
            TitleLine:= FindLine('/exec/obidos/ASIN/',AmazonPage, 0);
          if (LineNr > TitleLine) then
            LineNr:=-1;
          if LineNr > -1 then
            Line := AmazonPage.GetString(LineNr);
            BeginPos := Pos('src="http://images.amazon.com/images/P/', Line) + 4;
            Value := StringReplace(Value, 'TZZZZZZZ', 'LZZZZZZZ');
            Value := StringReplace(Value, 'THUMBZZZ', 'LZZZZZZZ');
            GetPicture(Value, ExternalPictures);
            FoundOnAmazon := True;
        LineNr := FindLine('http://images.amazon.com/images/P/', AmazonPage, LineNr);
        if LineNr < TitleLine then
          BeginPos := Pos('src="', Line) + 4;
      AmazonPage.Free;
  end; // if ImportLargePicture
  if not FoundOnAmazon then
    {  not found on Amazon, so taking what's available directly on IMDB.  }
    LineNr := FindLine('<img border="0" alt="cover"', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('src="', Line) + 4;
      EndPos := pos('"', Line);
function TransformTitle(Title: string): string;
  Value: string;
  Words: array of string;
  Replace,Original: string;
  Index, CommaCount: Integer;
Begin
  // Original Title
  Result:=Title;
  Setarraylength(Words,11);
  Words[0]:=' In ';
  Words[1]:=' On ';
  Words[2]:=' Of ';
  Words[3]:=' As ';
  Words[4]:=' The ';
  Words[5]:=' At ';
  Words[6]:=' And A ';
  Words[7]:=' And ';
  Words[8]:=' An ';
  Words[9]:=' To ';
  Words[10]:=' For ';
  SetArrayLength(Articles,35);
  Articles[0]:=' The';
  Articles[1]:=' a';
  Articles[2]:=' An';
  Articles[3]:=' Le';
  Articles[4]:=' L''';
  Articles[5]:=' Les';
  Articles[6]:=' Der';
  Articles[7]:=' Das';
  Articles[8]:=' Die';
  Articles[9]:=' Des';
  Articles[10]:=' Dem';
  Articles[11]:=' Den';
  Articles[12]:=' Ein';
  Articles[13]:=' Eine';
  Articles[14]:=' Einen';
  Articles[15]:=' Einer';
  Articles[16]:=' Eines';
  Articles[17]:=' Einem';
  Articles[18]:=' Il';
  Articles[19]:=' Lo';
  Articles[20]:=' La';
  Articles[21]:=' I';
  Articles[22]:=' Gli';
  Articles[23]:=' Le';
  Articles[24]:=' Uno';
  Articles[25]:=' Una';
  Articles[26]:=' Un''';
  Articles[27]:=' O';
  Articles[28]:=' Os';
  Articles[29]:=' As';
  Articles[30]:=' El';
  Articles[31]:=' Los';
  Articles[32]:=' Las';
  Articles[33]:=' Unos';
  Articles[34]:=' Unas';
  // Count the Comma in The Title
  CommaCount := 0;
  EndPos := 0;
  Value := Title;
     BeginPos := Pos(',', Value);
       Delete(Value, 1, BeginPos);
       CommaCount := CommaCount + 1;
       EndPos := EndPos + BeginPos;
  until( Pos(',',Value) = 0);
  // Compare the Article to a list of known ones
  for Index := 0 to 34 do
    if Pos(Articles[Index], Value) <> 0 then
       CommaCount := 1;
       BeginPos := EndPos;
  if (BeginPos > 0) and (CommaCount = 1) then
    Value := Copy(Title, BeginPos + 1, Length(Title));
    Value := Trim(Value);
    Result := Value + ' ' + Copy(Title, 1, BeginPos - 1);
  BeginPos := Pos(': ', Result);
    Result := StringReplace(Result, ': ', ' - ');
  Result := AnsiMixedCase(Result, ' ');
  for Index := 0 to 10 do
    if Pos(Words[Index],Result) <> 0 then
      Original := Words[Index];
      Replace := AnsiLowerCase(Original);
      Result := StringReplace(Result, Original, Replace);
  Result := StringReplace(Result, ' - the ', ' - The ');
  Result := Trim(Result);
function GetDescriptions(Address: string): string;
  Line, Value: string;
  BeginPos, EndPos,Longest: Integer;
  Result := '';
  Longest := 0;
  LineNr := FindLine('<p class="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</p>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</p>', Line) > 0) or (LineNr = Page.Count);
    HTMLDecode(Value);
    PickListAdd(Value);
    if Length(Value) > Longest then
      Result := Value;
      Longest := Length(Value);
    LineNr := FindLine('<p class="plotpar">', Page, LineNr);
function AddMoviesTitles(Page: TStringList; Tag: string): string;
  StartPos: Integer;
  Result := '';
  LineNr := FindLine(tag, Page, 0);
  if LineNr > -1 then
    HTMLRemoveTags(Line);
    PickTreeAdd(Trim(Line), '');
    LineNr := LineNr + 5;
    StartPos := pos('href="', Line) + 5;
    Delete(Line, 1, StartPos);
    Result := Copy(Line, 1, pos('">', Line) - 1);
procedure AnalyzePageCulturalia(Address: string);
  Code: string;
  TitleFound: Boolean;
  TitleFound := False;
  LineNr := 1;
  if Pos('No se ha encontrado ningún artículo por título', Page.Text) = 0 then
    TitleFound := True;
    Code := GetValueAfter(Page.GetString(LineNr), 'Codigo = ');
    Address := (BaseURLCulturalia + '?catalogo=1&codigo=' + Code);
  if TitleFound then
    AnalyzeMoviePageCulturalia(Address);
procedure AnalyzeMoviePageCulturalia(Address: string);
  Comments: string;
  strTitle: string;
  strSinopsis: string;
  tmp: string;
  strTitle := GetValueAfter(Page.GetString(1), 'Titulo = ');
  if copy(strTitle, Length(strTitle), Length(strTitle)) = '.' then
    tmp := Copy(strTitle, 1, Length(strTitle) -1);
    tmp := strTitle;
  SetField(fieldTranslatedTitle, TransformTitle(tmp));
  tmp := GetValueAfter(Page.GetString(2), 'Titulo original = ');
  SetField(fieldOriginalTitle, TransformTitle(tmp));
  SetField(fieldYear, GetValueAfter(Page.GetString(3), 'Año = '));
  SetField(fieldCategory, GetValueAfter(Page.GetString(4), 'Genero = '));
  SetField(fieldCountry, GetValueAfter(Page.GetString(5), 'Nacion = '));
  SetField(fieldDirector, GetValueAfter(Page.GetString(6), 'Director = '));
  SetField(fieldActors, GetValueAfter(Page.GetString(7), 'Actores = '));
  SetField(fieldProducer, GetValueAfter(Page.GetString(8), 'Productor = '));
  Comments := 'Guión: ' + GetValueAfter(Page.GetString(9), 'Guion = ');
  Comments := Comments + #13#10 + 'Fotografía: ' + GetValueAfter(Page.GetString(10), 'Fotografia = ');
  Comments := Comments + #13#10 + 'Música: ' + GetValueAfter(Page.GetString(11), 'Musica = ');
  LineNr := FindLine('Sinopsis = ', Page, 0);
  strSinopsis := GetValueAfter(Line, 'Sinopsis = ');
  while pos('URL = ', Line) = 0 do
    strSinopsis := strSinopsis + #13#10 + Line;
  HTMLRemoveTags(strSinopsis);
  SetField(fieldDescription, StringReplace(StringReplace(strSinopsis, '"', '"'), '"', '"'));
  LineNr := FindLine('URL = ', Page, 0);
  if LineNr <> -1 then
    SetField(fieldURL, GetValueAfter(Page.GetString(LineNr), 'URL = '));
    GetPicture(GetValueAfter(Page.GetString(LineNr), 'Imagen = '), ExternalPictures);
function GetValueAfter(Line, Identifier: string): string;
  if Pos(Identifier, Line) = 1 then
    Result := Copy(Line, Length(Identifier)+1, Length(Line))
    Result := '';
  SetArrayLength(Articles,11);
  Articles[0]:='Lo ';
  Articles[1]:='La ';
  Articles[2]:='Le ';
  Articles[3]:='Uno ';
  Articles[4]:='Una ';
  Articles[5]:='Un ';
  Articles[6]:='El ';
  Articles[7]:='Los ';
  Articles[8]:='Las ';
  Articles[9]:='Unos ';
  Articles[10]:='Unas ';
  if CheckVersion(3,4,0) then
     donde := '&donde=2';
       MovieName := GetField (fieldTranslatedTitle);
       donde := '&donde=1';
       Input('Importar de Culturalia', 'Introduce el Titulo de la Pelicula:', MovieName);
       donde := '&donde=' + defdonde;
     if MovieName <> '' then
      tmp := MovieName;
      if Copy(tmp, Length(tmp), Length(tmp)) = '.' then
        MovieName := Copy(tmp, 1, Length(tmp) -1);
      AnalyzePageCulturalia(BaseURLCulturalia + '?catalogo=1&texto=' + UrlEncode(MovieName) + donde);
      AnalyzePageIMDB('http://us.imdb.com/Tsearch?title='+UrlEncode(GetField(fieldOriginalTitle)));
Enjoy!
Regards, folgui.
KaBeCi
Post by KaBeCi »
great job!!!! it works very well, havent seen any bug yet, but i see something we were talking before, about how culturalia (and imdb too)doesnt give the correct result for some movies. If you use the single script, you can choose the correct movie and its all right, but with the batch... you got wrong info for your movies and may be you dont realize it if you run 100+ movies at once (or you have to check one by one to see if its ok).
the problem is the results order, culturalia seems to alfabetically order'em, and imdb as "most popular", but the usefull order for us should be "the movie who has less non entered words". well, this sounds too complicated, i know, i'll explain it:
lets search for the movie "Ugly"
on imdb and culturalia, the first result is "Coyote Ugly". WTF, i wanted the info for movie "Ugly", not "Coyote Ugly"
so what i say is if we search for "Ugly" and the scripts receives this list (culturalia):
Bar Coyote, El (Coyote Ugly), 2000
Hermanastra, La (Conffessions of an Ugly Stepsister), 2002
Rabbit Ears: The Ugly Ducking. (Rabbit Ears: The Ugly Ducking), 1985
Ugly, The (The Ugly), 1997
its obvious that the correct movie is "Ugly, The", so how to automate the choosing? we've searched for "Ugly", the result "Bar Coyote, El (Coyote Ugly), 2000" has 5 words that were not in the search. The result "Hermanastra, La (Conffessions of an Ugly Stepsister), 2002" has 7 words that were not in the search... and the result "Ugly, The (The Ugly), 1997" has only 3 words that were not in the search, so that one is the correct result.
This is a common bug of ALL batch scripts, but its worst with culturalia because they alfabetically order the results, so if there are more than one, most probably you got the wrong one.
well, thats all. thanks. may be i should opened a new thread...
KaBeCi wrote: may be i should opened a new thread...
please, no, there is already enough threads about Culturalia :p
folgui
Post by folgui »
Hello!
KaBeCi this is the "main" thread to improve this script so ATM (at the moment), no more threads.
I think it's fixed ATM! Made some changes.
Otherwise, we'll have problem with some movies like "La Hermanastra", because culturalia returns 2 posibilities :
Codigo = 16850
Titulo = Hermanastra, La.
Titulo original = Confessions of an Ugly Stepsister
Año = 2002
Codigo = 12939
Titulo original = The Stepsister
Año = 1997
Like you see the same title in spanish for both. I think, the only solution is use part of the original title like "confessions of an ugly" or check after import, the year or original title to confirm it's ok. Few movies like this example, so don't worry, be happy :lol:
Regards, folgui.
KaBeCi
Post by KaBeCi »
well... i've been away for a while, i'm back now, i used the script for a lot of movies with great results. But... when a movie is not found on culturalia, the script "hangs" (and deletes the original title), but that doesnt bothers me.... what it really bothers me is when it get the wrong movie because sometimes you dont realize it.
try to search for "Narc"
you'll get "La ruta de los narcoticos" on iMDB AND Culturalia. why? i dont know, but if i use the culturalia single movie script, "Narc" is the first movie, also with iMDB single movie (large picture).
thanks
If i search for "Narc" i get "Narc" info. Culturalia returns:
Codigo = 18721<br>Titulo = Narc.<br>Titulo original = Narc<br>Año = 2002
Codigo = 17468<br>Titulo = Narcos.<br>Titulo original = Narcos<br>Año = 1992
Codigo = 17728<br>Titulo = Ruta de los narcóticos, La.<br>Titulo original = La ruta de los narcóticos<br>Año = 1962
So, it gets the first movie info, not "La Ruta de los narcóticos". And this is OK. Don't know why it gives you the 3rd. movie. ¿Another movie example like "narc" to check?
I'll review and work on the "not found" at culturalia problem.
Regards, folgui.
KaBeCi
KaBeCi
Post by KaBeCi »
is because is "narc" not "Narc" i wrote it wrong on my last post
but its not a big problem anyway, forget about it
folgui
Post by folgui »
Script modified.
Added an option to obtain different case of titles. This option is a "const" at beginning of script: TitleMixedCase
By default is "False", that means all letters lowercase except first one. With "True" we obtain a mixed case, with first letter of each word in Uppercase.
Set it as you like.
Regards, folgui
KaBeCi
Post by KaBeCi »
hi Folgui, thanks for your work in this script
2 only things to know about:
When it doesnt find a movie, it hangs up (and i've to press the stop button)
Retaking something i told you before, search for the movie "Casino" and you'll see... you'll get the info for "Zafarrancho en el Casino" instead of "Casino".
gracias
folgui
Post by folgui »
It gets "Casino" for me, either if i put it in original o translated title. Sure you are using the version posted here?
Otherwise, i've already copied again my latest version in the first message, so get it from here.
Yes, if it doesn't find a movie it returns to the scripts window and you have to press "Stop" and "Close", for one movie, no problem; but for several movie import it's bad. I'll give it a look.
Regards, folgui
folgui
Post by folgui »
Fixed the problem (hangup) when script doesn't find a movie in Culturalia.
The latest script is always the one posted in the first message of this thread.
Regards, folgui
KaBeCi
Post by KaBeCi »
the script is working great!!! thank you!!!!!
sometimes i get the HTTP/1.1 500 internal server error, but i dont know if its your script, imdb, culturalia or my PC
thanks folgui!!!!
if ExternalPictures is set to true, when importing pic from Culturalia it always save it internally.
Old code (line 991)
    GetPicture(GetValueAfter(Page.GetString(LineNr), 'Imagen = '), False);
Corrected Code (line 991)
    GetPicture(GetValueAfter(Page.GetString(LineNr), 'Imagen = '), Externalpictures);
i've realized it when i saw the TOO BIG size of my catalog, it doesnt fit on a floppy anymore and zip/rar wont compress too much.
BTW, does anyone knows a way to externalize all pictures??? (i'm doing it manually, save it, delete it and then linking it to the saved one)
KaBeCi wrote: BTW, does anyone knows a way to externalize all pictures??? (i'm doing it manually, save it, delete it and then linking it to the saved one)
Save to XML, the program will ask if it can make external pictures.
Then you can save it back to AMC or keep it in XML.
folgui
Post by folgui »
Thanks KaBeCi ;)
Script updated with what you comment two messages above.
The same applies to the other culturalia scripts, so also updated.
Regards, folgui
KaBeCi
Post by KaBeCi »
thanks ANTP, you're the best... i know there could be a much easy way to do that, now my catalog is 200k and 70k zipped (before it was 3MB and 2.8 zipped), fits fine on 1 floppy. :grinking: :grinking: :grinking:
is there any difference to have it in XML or AMC???
XML is a text format, where tags are used, a little like HTML, and this can be used more easily by other people if they want to import it in other applications. You can see it with a text editor (notepad) or a XML parser (Internet Explorer or Mozilla).
AMC is a binary format.
Uncompressed, the AMC file is a little smaller.
But in the case that the file is damaged, the XML file will be easier to repair ;)
After IMDB changes (see viewtopic.php?t=1080 about that), I updated this script :
http://www.antp.be/temp/Culturalia+IMDB%20(batch).ifs
folgui
Post by folgui »
Thank you very much antp! :grinking:
folgui
Post by folgui »
Script updated.
The latest scripts in version 3.4.2 of AMC (date 09/01/2004) didn't include all code of the version published here, so updated with that code and with the code modifications by Antoine to support changes in IMDB a few months ago.
The code at first message of this thread is the latest updated/working version of the script. So copy/paste/save it.
Regards, folgui
