IMDB script with support for alternative titles (translated
Willspo
Post by Willspo »
Hello!
I've made a little addition to the IMDB script with support for translated title. The script let you choose a title from the "also known as" list in IMDB as translated title.
It's really usefull for Hongkong movies!
The script is pretty sloppy (never tried pascal before) but worked for all my movies.
  // Alternative title
  LineNr := FindLine('Also Known As:', Page, 0);
  if LineNr > -1 then
    LineNr := LineNr + 1;
    PickListClear;
    BeginPos := pos('>', Line) + 1;
    EndPos := pos('(', Line) - 1;
    HTMLDecode(Value);
    PickListAdd(Value);
    EndPos := pos(')<', Line) + 1;
    Line := copy(Line, EndPos, Length(Line) - 1);
    until Line = '</TD></TR>';
    Value := '';
    if PickListExec('Select an alternative title for "' + MovieName + '"', Value) then
    setField(fieldTranslatedTitle, Value);
Place this code inside AnalyzeMoviePage(Page: TStringList)
/w
some improvements
Thank you for this! I've been thinking of this some time ago but I was too lazy to do it :)
I made some improvements to your script: It loads from akas.imdb.com, which knows all international alternative titles. I had to change some things in other parts of the script, so I'll post the whole thing.
I also include some changes I made a while ago to include actors' role names (Ex: "Arnold Schwarzenegger (as The Terminator)").
OK, here comes the script:
// GETINFO SCRIPTING
// IMDB (US) import with large pictures whenever possible
 *      IMDB (US), http://akas.imdb.com            *
 *  (c) 2002 Antoine Potten    antoine@buypin.com  *
 *  Improvements by Danny Falkov, Kai Blankenhorn  *
 *  and Willspo                                    *
 *  For use with Ant Movie Catalog 3.3.1           *
program IMDb;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
//  Page.Text := Page2;
  if pos('<TITLE>IMDb', Page.Text) = 0 then
    AnalyzeMoviePage(Page)
    LineNr := 0;
    LineNr := FindLine('<H2><A NAME="top">Most popular searches</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Most popular searches', '');
    LineNr := FindLine('<H2><A NAME="mov">Movies</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Movies', '');
    LineNr := FindLine('<H2><A NAME="tvm">TV-Movies</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('TV-Movies', '');
    LineNr := FindLine('<H2><A NAME="tvs">TV series</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('TV Series', '');
    LineNr := FindLine('<H2><A NAME="vid">Made for video</A></H2>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Made for video', '');
      AnalyzePage(Address);
  Line, Value, TempCopy, FullValue, Value2: string;
  BeginPos, EndPos: Integer;
  if LineNr > -1 then
    PickListClear;
    LineNr := 0;
    while (pos('<BR>', Line)>0) AND (LineNr<100) do begin
      while copy(Line, 1, 1)='<' do begin
        BeginPos := pos('<', Line);
        EndPos := pos('>', Line);
        Delete(Line, BeginPos, EndPos);
      Value := copy(Line, 1, EndPos);
      HTMLDecode(Value);
      PickListAdd(Value);
      BeginPos := pos('<BR>', Line);
      Line := copy(Line, BeginPos, Length(Line)-BeginPos);
    Value := '';
  // Original Title & Year
  LineNr := FindLine('<TITLE>', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<TITLE>', Line);
    if BeginPos > 0 then
      BeginPos := BeginPos + 7;
    EndPos := pos('(', Line);
    if EndPos = 0 then
      EndPos := Length(Line);
    HTMLDecode(Value);
      EndPos := pos(')', Line);
      SetField(fieldYear, Value);
  // Picture
  LineNr := FindLine('<IMG SRC="http://posters.imdb.com/', Page, 0);
  if LineNr < 0 then
    LineNr := FindLine('<A HREF="/ImageView?', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<A HREF="/ImageView?', Line) + 29;
    EndPos := pos('"><IMG SRC', Line);
    if (BeginPos > 10) and (EndPos > 0) then
      Value := 'http:' + copy(Line, BeginPos, EndPos - BeginPos);
      //in case there are multiple pics, replace Value with small pic
      if ((pos('.jpg', Value) = 0) and (pos('.gif', Value) = 0)) then
        BeginPos := pos('<IMG SRC="', Line) + 10;
        EndPos := pos('ALT="cover" ', Line);
          Value := copy(Line, BeginPos, EndPos - BeginPos - 2);
      GetPicture(Value, False); // False = do not store picture externally ; store it in the catalog file
  // Rating
  if LineNr > -1 then
    BeginPos := pos('<B>', Line) + 3;
    SetField(fieldRating, Value);
  // Director
  if LineNr > -1 then
    FullValue := '';
      EndPos := pos('</A>', Line);
        if FullValue <> '' then
    until (pos('<BR><BR>', Line) > 0) or (LineNr >= Page.Count-1) or (Line = '<BR>');
    HTMLDecode(FullValue);
  // Actors
  LineNr := FindLine('Cast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('cast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('Complete credited cast', Page, 0);
  if LineNr > -1 then
    FullValue := '';
      if pos('<TD VALIGN="TOP">', Line) > 0 then
          BeginPos := pos('.... </TD><TD VALIGN="TOP">', Line);
            EndPos := pos(' </TD></TR>', Line);
            BeginPos := BeginPos + 27;
            if Value2 <> '' then
              Value := Value + ' (as ' + Value2 + ')';
        Line := '';
    until Line = '';
  //Country
  LineNr := FindLine('Country</B>', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Category
  LineNr := FindLine('Genre</B>', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Description
  LineNr := FindLine('Plot Summary:', Page, 0);
  if LineNr < 1 then
    LineNr := FindLine('Plot Outline:', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('</B>', Line) + 4;
    EndPos := pos('<A HREF', Line);
    if EndPos < 1 then
    PickListClear;
    HTMLDecode(Value);
    PickListAdd(Value);
    BeginPos := pos('/Plot?', Line);
    EndPos := pos('"> (more)', Line);
    GetDescriptions(Value);
    Value := '';
    if PickListExec('Select a description for "' + MovieName + '"', Value) then
  // Comments
  LineNr := FindLine('Summary:</B>', Page, 0);
  if LineNr > -1 then
      BeginPos := 0;
         BeginPos := pos('<P>', Line);
      until BeginPos > 0;
      BeginPos := BeginPos + 3;
         if (copy(line, Length(Line), 1)=' ') OR (Line = '<BLOCKQUOTE><P>') then
           Line := Line + Page.GetString(LineNr);
           Line := Line + ' ' + Page.GetString(LineNr);
         EndPos := pos('</P>', Line);
      until EndPos > 0;
    HTMLDecode(Value);
    Value := StringReplace(Value, '<BR>', #13#10);
    Value := StringReplace(Value, #13#10+' ', #13#10);
  //URL
  LineNr := FindLine('<BASE HREF="', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<BASE HREF="', Line) + 12;
    EndPos := pos('">', Line);
    SetField(fieldURL, Value);
  //Length
  LineNr :=FindLine('Runtime</B>:', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('</B>', Line) + 7;
    EndPos := pos(' /', Line);
    if EndPos = 0 then
      EndPos := pos('</TD>', Line);
    SetField(fieldLength, Value);
  // Language
  LineNr := FindLine('Language</B>:', Page, 0);
  if LineNr > -1 then
    if EndPos = 0 then
  DisplayResults;
procedure GetDescriptions(Address: string);
  Line, Value: string;
  Page.Text := GetPage('http://akas.imdb.com' + Address);
  LineNr := FindLine('<P CLASS="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</P>', Line) > 0) or (LineNr = Page.Count);
    PickListAdd(Value);
    LineNr := FindLine('<P CLASS="plotpar">', Page, LineNr);
  StartPos: Integer;
    if pos('<LI>', Line)>0 then begin
      StartPos := pos('="', Line);
      if StartPos > 0 then
        Startpos := Startpos + 2;
        MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
        MovieTitle := copy(Line, StartPos, pos('</A>', Line) - StartPos);
        HTMLDecode(Movietitle);
        PickTreeAdd(MovieTitle, 'http://akas.imdb.com' + MovieAddress);
  until pos('</OL>', Line) > 0;
  if CheckVersion(3,3,0) then
    if Input('IMDb Import', 'Enter the title of the movie:', MovieName) then
//      AnalyzePage('http://akas.imdb.com/Tsearch?title='+UrlEncode(MovieName)+'&restrict=Movies+only');
      AnalyzePage('http://akas.imdb.com/Tsearch?title='+UrlEncode(MovieName));
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.3.0)');
Kai
Willspo
new version
Post by Willspo »
New version for new IMDB script.
  LineNr := FindLine('Also Known As', Page, 0);
  if LineNr > -1 then
    PickListClear;
    Line := copy(Line, pos('<br>', Line) + 4, Length(Line) - 1);
      Value := copy(Line, 0, EndPos);
      HTMLDecode(Value);
      PickListAdd(Value);
      EndPos := pos('>', Line) + 1;
    until Length(Line) = 0;
    Value := '';
