Culturalia+IMDB (Single Movie) Script, Latest Version
folgui
Post by folgui »
Hi!
Well, i've been working in a script that obtains the most data from culturalia and the one that culturalia doesn't give, from IMDB. Otherwise, it's simple to configure script to obtain more data from IMDB, if somebody needs it.
It's a first release, it works with the movies that i tried, but sure it has some bugs and needs fixes. Try it and reply with them.
LATEST VERSION OF SCRIPT :
// GETINFO SCRIPTING
// Culturalia+IMDB
*  Script merged by Jose Miguel Folgueira, based   *
*  on a similar script merged by Antoine Potten    *
*  Movie importation script for:                   *
*    Culturalia, http://www.culturalianet.com      *
*  Original version made by David Arenillas        *
*  New version made by Antoine Potten              *
*  Contributors:                                   *
*    Jose Miguel Folgueira                         *
*    RedDwarf                                      *
*    Hades666                                      *
*    KaBeCi                                        *
*    Pollopolea                                    *
*  Thanks to Culturalia's webmaster for his help   *
*  and for providing more direct access to his     *
*  database                                        *
*      IMDB (US), http://us.imdb.com               *
*  TransformTitle function from IMDB (US) Script   *
*  (c) 2002-2004 Antoine Potten                    *
*                          software@antp.be        *
*  (c) 2002 Antoine Potten    antoine@buypin.com   *
*  Contributors :                                  *
*    Danny Falkov                                  *
*    Kai Blankenhorn                               *
*    lboregard                                     *
*    Ork <ork@everydayangels.net>                  *
*    Trekkie <Asimov@hotmail.com>                  *
*    Youri Heijnen                                 *
*  For use with Ant Movie Catalog 3.4.x            *
*  www.ant.be.tf/moviecatalog ··· www.buypin.com   *
*  The source code of the script can be used in    *
*  another program only if full credits to         *
*  script author and a link to Ant Movie Catalog   *
*  website are given in the About box or in        *
*  the documentation of the program                *
program Culturalia_IMDb;
  BaseURLCulturalia = 'http://www.culturalianet.com/bus/catalogo.php';
  UseLongestDescIMDB = False; // If set to False shortest description available will be imported, faster since taken from main page
  // Set the following constants to True to import field, or False to skip field (fiels to import from IMDB). By default, only the fields not available at  Culturalia are set to True.
  // Pon las siguientes constantes a True para importar campo o False para no hacerlo (campos a importar de IMDB). Por defecto, sólo los campos no disponibles en Culturalia están a True.
  ImportActors = False;
  ImportCategory = False;
  ImportComments = False;
  ImportCountry = False;
  ImportDescription = False;
  ImportDirector = False;
  ImportLength = True;
  ImportLanguage = False;
  ImportOriginalTitle = False;
  ImportTranslatedTitle = False;
  LeaveOriginalTitle = False; // True will get Translated Title, yet Original Title field will remain same
  ImportPicture = False;
  ImportLargePicture = False; // If set to False small pic will be imported
  ImportRating = True;
  ImportURL = False;
  ImportYear = False;
  TitleMixedCase = False; // If true, each letter of each word of title begins with Uppercase. If false, the script transforms the titles in lowercase except first word
  ExternalPictures = False;
    { True: Pictures will be stored as external files in the folder of the
            catalog
      False: Pictures will be stored inside the catalog (only for .amc files) }
  ManualPictureSelect = False;
    { True: If no Title Match found a picture selection window appears
      False: Revert to IMDB picture }
  // Donde vamos a buscar en el caso de no haber introducido ni el título original ni el traducido en los campos correspondientes, sino en la ventana que
  // se abre y nos lo solicita.
  // 1-Titulo traducido, 2-Titulo original, 3-General
  // What type of search in case we don't write the original title nor traslated one in the corresponding fields, we do it in the input box.
  // 1-Translated title, 2-Original Title, 3-General
  defdonde='1';
  MovieName, Titulo: string;
  MovieURL: string;
  tmp: string;
  donde: string;
  Articles: array of string;
  Index: Integer;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
procedure AnalyzePageIMDB(Address: string);
  MovieURL: string;
  if pos('<title>IMDb', Page.Text) = 0 then
    AnalyzeMoviePageIMDB(Page)
    MovieURL := AddMoviesTitles(Page, '<b>Exact Matches</b>');
    if MovieURL = '' then
      MovieURL := AddMoviesTitles(Page, '<b>Partial Matches</b>');
      MovieURL := AddMoviesTitles(Page, '<b>Approximate Matches</b>');
    if MovieURL <> '' then
      AnalyzePageIMDB(MovieURL);
function FindValue(BeginTag, EndTag: string; Page: TStringList; var LineNr: Integer; var Line: string): string;
  BeginPos, EndPos: Integer;
  Value: string;
  Result := '';
  Value := '';
  BeginPos := Pos(BeginTag, Line);
  if BeginPos > 0 then
    BeginPos := BeginPos + Length(BeginTag);
    if BeginTag = EndTag then
      Delete(Line,1,BeginPos-1);
      BeginPos := 1;
    EndPos := pos(EndTag, Line);
    while ((EndPos = 0) and (LineNr < Page.Count-1 )) do
      Value := Value + copy(Line, BeginPos, Length(Line) - BeginPos);
      // Next Line
      BeginPos := 1;
      LineNr := LineNr + 1;
      if Value = '' then
        Exit;
      EndPos := Pos(EndTag, Line);
  Result := Value;
procedure AnalyzeMoviePageIMDB(Page: TStringList);
  Line, Value, Value2, FullValue, OldOriginalTitle: string;
  LineNr, Desc, i: Integer;
  OldTitleParts, AllTitles: TStringList;
  LongDescr: Boolean;
  LongDescr := UseLongestDescIMDB;
  if (LongDescr) and (Pos('<a href="plotsummary">', Page.Text) = 0) then
    LongDescr := False;
  MovieURL := 'http://imdb.com/title/tt' + Copy(Page.Text, Pos('?pending&add=', Page.Text) + 17, 7);
  // URL
  if ImportURL then
    SetField(fieldURL, MovieURL);
  AllTitles := TStringList.Create;
  // Original Title & Year
  if (ImportOriginalTitle) or (ImportYear) then
    if LineNr > -1 then
      BeginPos := pos('<title>', Line);
        BeginPos := BeginPos + 7;
      EndPos := pos('(', Line);
      if EndPos = 0 then
        EndPos := Length(Line);
      HTMLDecode(Value);
      if ImportOriginalTitle then
        OldOriginalTitle := GetField(fieldOriginalTitle);
      if (ImportTranslatedTitle) and not (LeaveOriginalTitle) then
        EndPos := Pos('/I', Line);
        if EndPos < BeginPos then
          EndPos := pos(')', Line);
        if ImportYear then
          SetField(fieldYear, Value);
  // Translated Title
  if ImportTranslatedTitle then
    OldTitleParts := TStringList.Create;
    // Tokenize OldOriginalTitle while removing certain chars/common words ("the", "of")
    Value := AnsiUpperCase(OldOriginalTitle);
    Value := StringReplace(StringReplace(Value, ',', ' '), ':', ' ');
    Value := StringReplace(StringReplace(Value, '(', ' '), ')', ' ');
    Value := StringReplace(StringReplace(Value, 'OF', ' '), 'THE', ' ');
    until Pos('  ', Value) = 0;
    Value := StringReplace(Trim(Value), ' ', ',');
    // Value now contains the original title (comma-separated) that was filled in before running the script
    Value2 := '';
    for i := 1 to Length(Value) do
      if Pos(',', Copy(Value, i, 1)) = 0 then
        Value2 := Value2 + Copy(Value, i, 1);
      if (Pos(',', Copy(Value, i, 1)) = 1) or (i = Length(Value)) then
        OldTitleParts.Add(Value2); // put each comma-separated value from Value into a separate string in TitleParts
        Value2 := '';
    for i := 0 to OldTitleParts.Count - 1 do
    // Begin comparing title parts (from the title originally filled in by moviedb owner) with
    // the 'true' Original Title (extracted from IMDb) to see if it's a foreign title and needs a Translated Title
      if Pos(OldTitleParts.GetString(i), AnsiUpperCase(GetField(fieldOriginalTitle))) <= 0 then
      begin // no match, must be a foreign title
        LineNr := FindLine('Also Known As', Page, 0);
        if LineNr > -1 then
          if Pos('Also Known As', Line) > 0 then
            BeginPos := Pos('Also Known As', Line) + 26;
            Value := Copy(Line, BeginPos, Length(Line) - BeginPos - 4);
            Value := StringReplace(Value, '<br>', '/ ');
            HTMLDecode(Value);
            SetField(fieldTranslatedTitle, Trim(Value));
    OldTitleParts.Free;
  // Rating
  if ImportRating then
    if LineNr > -1 then
      if Pos('/10', Line) > 0 then
        SetField(fieldRating, Value);
  // Language
  LineNr := FindLine('Language:', Page, 0);
  if LineNr > -1 then
    EndPos := pos('</a>', Line);
    if EndPos = 0 then
    if ImportLanguage then
  if ImportPicture then
    GetMoviePicture(Value, Page, AllTitles);
  AllTitles.Free;
  // Director
  if ImportDirector then
    if LineNr > -1 then
      FullValue := '';
          if FullValue <> '' then
        Delete(Line, 1, EndPos);
      until Pos('</a>', Line) = 0;
      HTMLDecode(FullValue);
  // Actors
  if ImportActors then
    LineNr := FindLine('ast overview', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('redited cast', Page, 0);
    if LineNr > -1 then
      FullValue := '';
        BeginPos := Pos('<td valign="top">', Line);
          Delete(Line, 1, BeginPos);
          if EndPos = 0 then
            EndPos := Pos('</td>', Line);
            BeginPos := pos('.... </td><td valign="top">', Line);
              EndPos := pos('</td></tr>', Line);
              BeginPos := BeginPos + 27;
              if Value2 <> '' then
                Value := Value + ' (as ' + Value2 + ')';
          Line := '';
      until Line = '';
  // Country
  if ImportCountry then
    LineNr := FindLine('Country:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
  if ImportCategory then
    LineNr := FindLine('Genre:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  //Description
  if ImportDescription then
    LineNr := FindLine('Plot Summary:', Page, 0);
    if LineNr < 1 then
      LineNr := FindLine('Plot Outline:', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('</b>', Line) + 5;
      EndPos := pos('<a href="/rg/', Line);
      if EndPos < 1 then
        if EndPos < 1 then
          EndPos := pos('<br><br>', Line);
        if EndPos < 1 then
      HTMLDecode(Value);
      HTMLRemoveTags(Value);
      if UseLongestDescIMDB then
        SetField(fieldDescription, GetDescriptions(MovieURL + 'plotsummary'))
  // Comments
  if ImportComments then
    LineNr := FindLine('<b>Summary:</b>', Page, 0);
    if LineNr > -1 then
      Value := '';
        EndPos := Pos('</blockquote>', Line);
        if EndPos = 0 then
          EndPos := EndPos - 1;
        Value := Value + Copy(Line, 1, EndPos) + ' ';
      until Pos('</blockquote>', Line) > 0;
      HTMLDecode(Value);
      Value := StringReplace(Value, #13#10+' ', #13#10);
  // Length
  if ImportLength then
    LineNr := FindLine('Runtime:', Page, 0);
    if LineNr > -1 then
      EndPos := pos(' min', Line);
      if EndPos = 0 then
        EndPos := pos('  /', Line);
      if EndPos = 0 then
      if Pos(':', Line) < EndPos then
        BeginPos := Pos(':', Line) + 1
        BeginPos := 1;
      SetField(fieldLength, Value);
  DisplayResults;
procedure GetMoviePicture(Language: string; Page, AllTitles: TStringList);
  Line, Value, Value2, Aka, PictureAddress: string;
  AmazonPage: TStringList;
  FoundOnAmazon, PickTreeSelected, PictureAvailable: Boolean;
  TitleRef, ImgRef, NoImage: string;
  LineNr, BeginPos, EndPos, PickTreeCount, ParagraphIndex, Index, TitleLine, LastMatch: Integer;
  FoundOnAmazon := False;
  if ImportLargePicture then
    // Find Alternate Titles for Movies which are not in English
    Aka := '';
    if Language <> 'English' Then
      LineNr:= FindLine('Also Known As',Page,0);
      EndPos:=0;
      if LineNr > -1 then
          Aka:=FindValue('<br>','<br>',Page,LineNr,Line);
          if Aka <> '' then
            BeginPos:=1;
            EndPos:=Pos('(',Line);
            if EndPos = 0 then
              EndPos := Length(Aka);
            Value := copy(Aka, BeginPos, EndPos - BeginPos - 1);
            Value:=TransFormIMDBTitle(Value);
            AllTitles.Add(Value);
        until (Pos('</td>', Line) > 0) or (Pos('Runtime', Line) > 0) or (Pos('MPAA', Line) > 0 ) or (Pos('Country', Line) > 0) or (Pos('Certification', Line) > 0);
    TitleRef:='dvd>';
    ImgRef:='dvd><img';
    NoImage:='/icons/dvd-no-image.gif';
    LineNr := FindLine('title="DVD available at Amazon.com"', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('title="VHS available at Amazon.com"', Page, 0);
      if LineNr > -1 then
        TitleRef:='video>';
        ImgRef:='video><img';
        NoImage:='/icons/video-no-image.gif';
    if LineNr > -1 then
      if(TitleRef='dvd>') then
        EndPos := pos('title="DVD', Line);
        BeginPos := pos('title="VHS', Line);
        while (BeginPos > 0) and (BeginPos<EndPos) do
          Delete(Line, 1, BeginPos+1);
      BeginPos := Pos('href="', Line) + 5;
      EndPos := Pos('"', Line);
      AmazonPage := TStringList.Create;
      AmazonPage.Text := GetPage('http://us.imdb.com' + Value);
      // Original Title
      Value2 := AllTitles.GetString(0);
      Value2 := TransFormIMDBTitle(Value2);
      PickTreeCount := 0;
      PickTreeAdd('Available Titles for matching a picture to: ' + Value2, '');
      ParagraphIndex := 1;
      LineNr := 0;
      LastMatch := -1;
      TitleLine := -1;
        LineNr := FindLine('<b>'+IntToStr(ParagraphIndex)+'.', AmazonPage, LineNr);
        if LineNr > -1 then
          TitleLine:=LineNr;
          Value:='';
          PictureAvailable:=False;
            TitleLine:=TitleLine +1;
            Line:= AmazonPage.GetString(TitleLine);
            BeginPos:=0;
            if Pos(TitleRef,Line) > 0 then
              if Pos(ImgRef,Line) = 0 then
                for Index:=0 to AllTitles.Count -1 do
                  Value2:=AllTitles.GetString(Index);
                  BeginPos:=Pos(Value2,Line);
                // Match not found
                if BeginPos = 0 then
                  BeginPos:=Pos(TitleRef,Line)+Length(TitleRef);
                  EndPos:=Pos('</a>',Line);
                  Value:=Copy(Line,BeginPos,EndPos-BeginPos);
                PictureAvailable:=(Pos(NoImage,Line) = 0);
                PictureAddress:=IntToStr(TitleLine);
          until (Pos('</table>',Line ) > 0);
          // Try to Find a Title Match
          if Pos(Value2,Line) > 0 then
            // Compare Current Title to Original
            BeginPos := Pos(TitleRef, Line) + Length(TitleRef) -1;
            EndPos:= Pos('(',Line);
            if EndPos = 0 Then
              EndPos := Pos('</a>', Line);
            Value:= Trim(Value);
            if Value = Value2 then
              if PictureAvailable then
                LastMatch:=LineNr;
                //Break
            PickTreeAdd(Value,PictureAddress);
            PickTreeCount:=PickTreeCount+1;
        ParagraphIndex:=ParagraphIndex+1;
      until (LineNr = -1);
      LineNr:=LastMatch;
      if (LineNr = -1) then
        // Handle Amazon Page Redirection(s)
        LineNr:= FindLine('You clicked on this item',AmazonPage,0);
          LineNr:=FindLine('Customers who bought',AmazonPage,0);
        // Display the Picture Selection Window
        if (LineNr = -1) and ManualPictureSelect and (PickTreeCount > 0) then
          PickTreeSelected:=PickTreeExec(PictureAddress);
          if PickTreeSelected then
            LineNr:=StrToInt(PictureAddress,0);
        if (LineNr > -1 ) then
          LineNr := FindLine('src="http://images.amazon.com/images/P/',AmazonPage, LineNr);
          if not PickTreeSelected then
            TitleLine:= FindLine('/exec/obidos/ASIN/',AmazonPage, 0);
          if (LineNr > TitleLine) then
            LineNr:=-1;
          if LineNr > -1 then
            Line := AmazonPage.GetString(LineNr);
            BeginPos := Pos('src="http://images.amazon.com/images/P/', Line) + 4;
            Value := StringReplace(Value, 'TZZZZZZZ', 'LZZZZZZZ');
            Value := StringReplace(Value, 'THUMBZZZ', 'LZZZZZZZ');
            GetPicture(Value, ExternalPictures);
            FoundOnAmazon := True;
        LineNr := FindLine('http://images.amazon.com/images/P/', AmazonPage, LineNr);
        if LineNr < TitleLine then
          BeginPos := Pos('src="', Line) + 4;
      AmazonPage.Free;
  end; // if ImportLargePicture
  if not FoundOnAmazon then
    {  not found on Amazon, so taking what's available directly on IMDB.  }
    LineNr := FindLine('<img border="0" alt="cover"', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('src="', Line) + 4;
      EndPos := pos('"', Line);
function TransformTitle(Title: string): string;
  Value: string;
  Words: array of string;
  Replace,Original: string;
  Index, CommaCount: Integer;
Begin
  // Original Title
  Result:=Title;
  Setarraylength(Words,11);
  Words[0]:=' In ';
  Words[1]:=' On ';
  Words[2]:=' Of ';
  Words[3]:=' As ';
  Words[4]:=' The ';
  Words[5]:=' At ';
  Words[6]:=' And A ';
  Words[7]:=' And ';
  Words[8]:=' An ';
  Words[9]:=' To ';
  Words[10]:=' For ';
  SetArrayLength(Articles,35);
  Articles[0]:=' The';
  Articles[1]:=' a';
  Articles[2]:=' An';
  Articles[3]:=' Le';
  Articles[4]:=' L''';
  Articles[5]:=' Les';
  Articles[6]:=' Der';
  Articles[7]:=' Das';
  Articles[8]:=' Die';
  Articles[9]:=' Des';
  Articles[10]:=' Dem';
  Articles[11]:=' Den';
  Articles[12]:=' Ein';
  Articles[13]:=' Eine';
  Articles[14]:=' Einen';
  Articles[15]:=' Einer';
  Articles[16]:=' Eines';
  Articles[17]:=' Einem';
  Articles[18]:=' Il';
  Articles[19]:=' Lo';
  Articles[20]:=' La';
  Articles[21]:=' I';
  Articles[22]:=' Gli';
  Articles[23]:=' Le';
  Articles[24]:=' Uno';
  Articles[25]:=' Una';
  Articles[26]:=' Un''';
  Articles[27]:=' O';
  Articles[28]:=' Os';
  Articles[29]:=' As';
  Articles[30]:=' El';
  Articles[31]:=' Los';
  Articles[32]:=' Las';
  Articles[33]:=' Unos';
  Articles[34]:=' Unas';
  // Count the Comma in The Title
  CommaCount := 0;
  EndPos := 0;
  Value := Title;
     BeginPos := Pos(',', Value);
       Delete(Value, 1, BeginPos);
       CommaCount := CommaCount + 1;
       EndPos := EndPos + BeginPos;
  until( Pos(',',Value) = 0);
  // Compare the Article to a list of known ones
  for Index := 0 to 34 do
    if Pos(Articles[Index], Value) <> 0 then
       CommaCount := 1;
       BeginPos := EndPos;
  if (BeginPos > 0) and (CommaCount = 1) then
    Value := Copy(Title, BeginPos + 1, Length(Title));
    Value := Trim(Value);
    Result := Value + ' ' + Copy(Title, 1, BeginPos - 1);
  BeginPos := Pos(': ', Result);
    Result := StringReplace(Result, ': ', ' - ');
  Result := AnsiMixedCase(Result, ' ');
  for Index := 0 to 10 do
    if Pos(Words[Index],Result) <> 0 then
      Original := Words[Index];
      Replace := AnsiLowerCase(Original);
      Result := StringReplace(Result, Original, Replace);
  Result := StringReplace(Result, ' - the ', ' - The ');
  Result := Trim(Result);
function GetDescriptions(Address: string): string;
  Line, Value: string;
  BeginPos, EndPos,Longest: Integer;
  Result := '';
  Longest := 0;
  LineNr := FindLine('<p class="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</p>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</p>', Line) > 0) or (LineNr = Page.Count);
    HTMLDecode(Value);
    PickListAdd(Value);
    if Length(Value) > Longest then
      Result := Value;
      Longest := Length(Value);
    LineNr := FindLine('<p class="plotpar">', Page, LineNr);
function AddMoviesTitles(Page: TStringList; Tag: string): string;
  StartPos: Integer;
  Result := '';
  LineNr := FindLine(tag, Page, 0);
  if LineNr > -1 then
    HTMLRemoveTags(Line);
    PickTreeAdd(Trim(Line), '');
    LineNr := LineNr + 5;
    StartPos := pos('href="', Line) + 5;
    Delete(Line, 1, StartPos);
    Result := Copy(Line, 1, pos('">', Line) - 1);
procedure AnalyzePageCulturalia(Address: string);
  Code, Title, TitleOrig, Year: string;
  if Pos('No se ha encontrado ningún artículo por título', Page.Text) > 0 then
    LineNr := 1;
    PickTreeAdd('Resultados más probables de la búsqueda:', '');
      Code := GetValueAfter(Page.GetString(LineNr), 'Codigo = ');
      Title := GetValueAfter(Page.GetString(LineNr+1), 'Titulo = ');
      TitleOrig := GetValueAfter(Page.GetString(LineNr+2), 'Titulo original = ');
      Year := GetValueAfter(Page.GetString(LineNr+3), 'Año = ');
      PickTreeAdd(Title + ' (' + TitleOrig + '), ' + Year, BaseURLCulturalia + '?catalogo=1&codigo=' + Code);
      AnalyzeMoviePageCulturalia(Address);
procedure AnalyzeMoviePageCulturalia(Address: string);
  Comments: string;
  strTitle: string;
  strSinopsis: string;
  tmp: string;
  strTitle := GetValueAfter(Page.GetString(1), 'Titulo = ');
  if copy(strTitle, Length(strTitle), Length(strTitle)) = '.' then
    tmp := Copy(strTitle, 1, Length(strTitle) -1);
    tmp := strTitle;
  SetField(fieldTranslatedTitle, TransformTitle(tmp));
  tmp := GetValueAfter(Page.GetString(2), 'Titulo original = ');
  SetField(fieldOriginalTitle, TransformTitle(tmp));
  SetField(fieldYear, GetValueAfter(Page.GetString(3), 'Año = '));
  SetField(fieldCategory, GetValueAfter(Page.GetString(4), 'Genero = '));
  SetField(fieldCountry, GetValueAfter(Page.GetString(5), 'Nacion = '));
  SetField(fieldDirector, GetValueAfter(Page.GetString(6), 'Director = '));
  SetField(fieldActors, GetValueAfter(Page.GetString(7), 'Actores = '));
  SetField(fieldProducer, GetValueAfter(Page.GetString(8), 'Productor = '));
  Comments := 'Guión: ' + GetValueAfter(Page.GetString(9), 'Guion = ');
  Comments := Comments + #13#10 + 'Fotografía: ' + GetValueAfter(Page.GetString(10), 'Fotografia = ');
  Comments := Comments + #13#10 + 'Música: ' + GetValueAfter(Page.GetString(11), 'Musica = ');
  LineNr := FindLine('Sinopsis = ', Page, 0);
  strSinopsis := GetValueAfter(Line, 'Sinopsis = ');
  while pos('URL = ', Line) = 0 do
    strSinopsis := strSinopsis + #13#10 + Line;
  HTMLRemoveTags(strSinopsis);
  SetField(fieldDescription, StringReplace(StringReplace(strSinopsis, '“', '"'), '”', '"'));
  LineNr := FindLine('URL = ', Page, 0);
  if LineNr <> -1 then
    SetField(fieldURL, GetValueAfter(Page.GetString(LineNr), 'URL = '));
    GetPicture(GetValueAfter(Page.GetString(LineNr), 'Imagen = '), False);
function GetValueAfter(Line, Identifier: string): string;
  if Pos(Identifier, Line) = 1 then
    Result := Copy(Line, Length(Identifier)+1, Length(Line))
    Result := '';
  SetArrayLength(Articles,11);
  Articles[0]:='Lo ';
  Articles[1]:='La ';
  Articles[2]:='Le ';
  Articles[3]:='Uno ';
  Articles[4]:='Una ';
  Articles[5]:='Un ';
  Articles[6]:='El ';
  Articles[7]:='Los ';
  Articles[8]:='Las ';
  Articles[9]:='Unos ';
  Articles[10]:='Unas ';
if CheckVersion(3,4,0) then
     donde := '&donde=2';
       MovieName := GetField (fieldTranslatedTitle);
       donde := '&donde=1';
       Input('Importar de Culturalia', 'Introduce el Titulo de la Pelicula:', MovieName);
       donde := '&donde=' + defdonde;
    If MovieName <> '' then
        tmp := MovieName;
        if Copy(tmp, Length(tmp), Length(tmp)) = '.' then
          MovieName := Copy(tmp, 1, Length(tmp) -1);
        AnalyzePageCulturalia(BaseURLCulturalia + '?catalogo=1&texto=' + UrlEncode(MovieName) + donde);
        AnalyzePageIMDB('http://us.imdb.com/Tsearch?title='+UrlEncode(GetField(fieldOriginalTitle)));
        DisplayResults;
Regards, folgui ;)
:grinking: nice
folgui
Post by folgui »
Script updated with the next fixes/updates:
- If there's a point at final of movie title before search, Culturalia doesn't find it. Fixed!. Sample: "Sunset Bvld.". Thanks KaBeCi.
- By default, culturalia's import of TranslatedTitle (spanish) has the articles at the final, after ', '. But then if you do a search of that, it doesn't find it. So changed to import article at beginning of title. Used same function as IDMB (US) script, works perfectly. Now after an import, if you do a new search, it works Ok. Thanks KaBeCi.
- If exists MovieName at 'fieldOriginalTitle' or "fieldTranslatedTitle' then it doesn't offer the window (input) to introduce movie name, otherwise, the window appears.
- Some code has been cleaned, not neccesary or superfluous.
- Other code has been added to add more IMDB import info if neccesary.
- Searchs now first for "OriginalTitle" rather than "TranslatedTitle", seems better for non-spanish users. Thanks KaBeCi.
- Error when OriginalTitle/TranslatedTitle fields are empty, it appears input window to introduce title, and after Ok, the result was a "Type mismatch". Fixed!. Thanks KaBeCi.
That's all ATM.
Enjoy!
Regards, folgui.
Pardon if the text is something incongruous but, as I do not have nor idea of English, I have used the translator of the Google, that or we know all how it translates.
There is some way to avoid that the title of the film leaves in capital letters to each word?
Example: La Gata Sobre El Tejado De Zinc
Thank you very much. Greetings.
folgui
Post by folgui »
There are some procedures to change the "case" of words so, i'll give them a review to see what i can do with it...
Regards, folgui
ummo
Muchas gracias.
Post by ummo »
Thank you very much by the annoyance.
And pardon not to put nick before, is that when I realized already it had pressed "Submit".
Greetings.
:grinking:
folgui
Post by folgui »
Script modified.
Added an option to obtain different case of titles. This option is a "const" at beginning of script: TitleMixedCase
By default is "False", that means all letters lowercase except first one. With "True" we obtain a mixed case, with first letter of each word in Uppercase.
Set it as you like.
Another fix is that this script didn't eliminate the spanish articles in search, like the "batch" one, so i've added the code. This caused a problem searching for "Los Ultimos dias del eden" for example.
Regards, folgui
ummo
Post by ummo »
Really, I enormously thank for all the annoyances to you that you take yourself. Thank you very much, sincerely.
Now no longer it leaves in capital letters and for me already it is sufficient. Although I have found a small one sticks with "¿A quien ama Gilbert Grape?", that it shows the title like "¿a quien ama gilbert grape?", leaving in small letters the first letter after the first question mark (not used in English but in Spanish) and the own names. But that would be isolated cases that they would be possible to be corrected by hand. The main work already is done.
Thank you very much again. A greeting.
folgui
Post by folgui »
Script updated, now the image import from culturalia uses the const "ExternalPictures" to import it as a external file or internal to AMC file.
Thanks to KaBeCi.
Regards, folgui
After IMDB changes (see viewtopic.php?t=1080 about that), I updated this script :
http://www.antp.be/temp/Culturalia+IMDB.ifs
folgui
Post by folgui »
Thank you very much antp! :grinking:
folgui
Post by folgui »
Script updated.
The latest scripts in version 3.4.2 of AMC (date 09/01/2004) didn't include all code of the version published here, so updated with that code and with the code modifications by Antoine to support changes in IMDB a few months ago.
The code at first message of this thread is the latest updated/working version of the script. So copy/paste/save it.
Regards, folgui
johnconnor
impossible movies
Post by johnconnor »
there are certain movies which are impossible to import into my catalog using this script.
For example, the film "Ghost in the shell" (http://imdb.com/title/tt0113568/) is never found by script, even executing it with the original title, part of the original or the translated title, ... anything!
Some other examples:
Nadar solo ( http://imdb.com/title/tt0305873/ )
Lilja 4-ever ( http://imdb.com/title/tt0300140/ )
Sexo con amor ( http://imdb.com/title/tt0363292/ )
Why is this? How can I solve it? :(
folgui
Post by folgui »
Hello!
It's simple, those movies are not in Culturalia's database, so main info is not imported. It only gets the rating, length, etc from IMDB as result, no other info.
Why don't you use some of the IMDB's exclusive scripts to get all the info for those movies.
Regards, folgui
Some updates to your code to use the correct field in culturalia search
See a new variable called "donde" and the last 40 lines of the code.I modified variable "donde "if we used original title, traslate or the tiled asked to the user. It work`s much better than the original one
Everybody sould modify the other sources of culturalia search to improve the results.
Thanks!
(Sorry for my english)
// Culturalia+IMDB
*  Contributors:                                   *
*    Pollopolea (Spain)                                   *
*    RedDwarf                                      *
*    Hades666                                      *
*    KaBeCi                                        *
*  database                                        *
*  Contributors :                                  *
*    Danny Falkov                                  *
*    Kai Blankenhorn                               *
*    lboregard                                     *
*    Youri Heijnen                                 *
  ImportURL = False;
  ImportYear = False;
            catalog
  MovieURL: string;
  tmp: string;
  donde: string;
  Index: Integer;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  TitleFound: Boolean;
  MovieURL: String;
  if pos('<TITLE>IMDb', Page.Text) = 0 then
    AnalyzeMoviePageIMDB(Page);
    TitleFound := False;
    LineNr := 0;
    LineNr := FindLine('<H2><A NAME="top">Most popular searches</A></H2>', Page, LineNr);
    if LineNr > -1 then
      MovieURL := AddMoviesTitles(Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="mov">Movies</A></H2>', Page, LineNr);
    if (LineNr > -1) And Not (TitleFound) then
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="tvm">TV-Movies</A></H2>', Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="vid">Made for video</A></H2>', Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="tvs">TV series</A></H2>', Page, LineNr);
      TitleFound := True;
    if TitleFound then
  Value: string;
  Result := '';
  Value := '';
      BeginPos := 1;
      // Next Line
      BeginPos := 1;
      if Value = '' then
        Exit;
  Result := Value;
  LongDescr: Boolean;
    LongDescr := False;
  MovieURL := 'http://imdb.com/title/tt' + copy(Page.Text, pos('<a href="/title/tt',Page.Text)+19, 7);
  // URL
  if (ImportURL)then
    if LineNr > -1 then
      if EndPos = 0 then
      HTMLDecode(Value);
      if (ImportTranslatedTitle) and Not (LeaveOriginalTitle) then
        if ImportYear then
  // Translated Title
    Value2 := '';
        Value2 := '';
        if LineNr > -1 then
    OldTitleParts.Free;
  // Rating
    if LineNr > -1 then
  // Language
  if LineNr > -1 then
    if EndPos = 0 then
  // Picture
  AllTitles.Free;
// Director
    if LineNr > -1 then
      FullValue := '';
  // Actors
    if LineNr = -1 then
    if LineNr > -1 then
      FullValue := '';
          if EndPos = 0 then
          Line := '';
      until Line = '';
  //Country
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
    if LineNr > -1 then
      HTMLDecode(Value);
  //Description
    if LineNr < 1 then
    if LineNr > -1 then
      EndPos := pos('<a href', Line);
      if EndPos < 1 then
        if EndPos < 1 then
      HTMLDecode(Value);
  // Comments
    if LineNr > -1 then
      Value := '';
        if EndPos = 0 then
      HTMLDecode(Value);
  // Length
    if LineNr > -1 then
      if EndPos = 0 then
      if EndPos = 0 then
        BeginPos := 1;
    Aka := '';
      EndPos:=0;
      if LineNr > -1 then
          if Aka <> '' then
            BeginPos:=1;
            if EndPos = 0 then
        until (Pos('Runtime',Line) > 0) or (Pos('MPAA',Line) > 0 );
    TitleRef:='dvd>';
    ImgRef:='dvd><img';
    if LineNr = -1 then
      if LineNr > -1 then
        TitleRef:='video>';
    if LineNr > -1 then
      // Original Title
      PickTreeCount := 0;
      LineNr := 0;
      LastMatch := -1;
      TitleLine := -1;
        if LineNr > -1 then
          TitleLine:=LineNr;
          Value:='';
            BeginPos:=0;
                // Match not found
            if EndPos = 0 Then
                LastMatch:=LineNr;
                //Break
      LineNr:=LastMatch;
            LineNr:=-1
          if LineNr > -1 then
      AmazonPage.Free;
       if we are lucky, a picture from amazon but directly linked in the page  }
    LineNr := FindLine('<img alt="cover" align="left" src="http://ia.imdb.com/media/imdb/', Page, 0);
    if LineNr < 0 then
      LineNr := FindLine('<img alt="cover" align="left" src="http://posters.imdb.com/', Page, 0);
    if LineNr < 0 then
    if LineNr > -1 then
      Value := StringReplace(Value, 'MZZZZZZZ', 'LZZZZZZZ'); // change URL to get the Large instead of Small image
  Value: string;
Begin
  // Original Title
  Result:=Title;
  Words[0]:=' In ';
  Words[1]:=' On ';
  Words[2]:=' Of ';
  Words[3]:=' As ';
  Words[4]:=' The ';
  Words[5]:=' At ';
  Words[7]:=' And ';
  Words[8]:=' An ';
  Words[9]:=' To ';
  Words[10]:=' For ';
  Articles[1]:=' a';
  Articles[2]:=' An';
  Articles[3]:=' Le';
  Articles[21]:=' I';
  Articles[27]:=' O';
  CommaCount := 0;
  EndPos := 0;
  Value := Title;
       CommaCount := 1;
       BeginPos := EndPos;
  If TitleMixedCase then
     Result := AnsiLowerCase(Result);
     Result := AnsiUpFirstLetter(Result);
  Result := '';
  Longest := 0;
    Value := '';
        BeginPos := 1;
      if EndPos < 1 then
      if Value <> '' then
    HTMLDecode(Value);
    PickListAdd(Value);
      Result := Value;
function AddMoviesTitles(Page: TStringList; var LineNr: Integer): String;
  StartPos: Integer;
    StartPos := pos('="', Line);
    if StartPos > 0 then
      Startpos := Startpos + 2;
      MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
      MovieTitle := copy(Line, StartPos, pos('</A>', Line) - StartPos);
      HTMLDecode(Movietitle);
      if Length(Result) <= 0 then
        Result := 'http://us.imdb.com' + MovieAddress;
  until pos('</OL>', Line) > 0;
    LineNr := 1;
    PickTreeAdd('Search results:', '');
  Comments: string;
  strTitle: string;
  tmp: string;
    tmp := strTitle;
    Result := '';
  Articles[0]:='Lo ';
  Articles[1]:='La ';
  Articles[2]:='Le ';
  Articles[5]:='Un ';
  Articles[6]:='El ';
       donde := '&donde=0';
        tmp := MovieName;
        DisplayResults;
[/list]
pollopolea
Post by pollopolea »
ups! I sent the code as you can see in the credits :P
thanks! :grinking:
folgui
Post by folgui »
Dont't know what you mean pollopolea. Sent code? What code? Where?
Regards, folgui.
I guess he means that he is the "guest" that posted the code to the forum, and forgot to login with his name to do that ;)
pollopolea
I posted the code and i forgot to write my name.
thanks antp for this program :D
folgui
Post by folgui »
Upss! I see, just a lapsus, sorry ;)
pollopolea, Thanks for the update.
Regards, folgui
