Selected Files
DarK_HawK
Selected Files
Post by DarK_HawK »
Hi There,
I need to rename some selected files in the Ant Renamer while the other Files is still visible.
I know i can add the files one set at a time, but is there a way i can rename just some selected files within the Ant Renamer window.
Thanks in advance and keep up the good work.
Cheers.
For the moment it is not possible, but it is a good idea of thing to add, thanks :D
