Easy CD import
Guest TX-P
Easy CD import
Post by Guest TX-P »
Hi...
First of all, thx for the prog... And most of all... Thx for keeping it free... Hope that everyone makes his contributions to keep it free...
But... I have couple of films on CD... Either way I am too stupid to find a way to get them in the Prog, or I am making it wrong... I can get the video format etc... But why doesn't he imort the filename as well for the Title?
And isn't there maybe a way, just to insert the CD, let him check it automatically and then take the next CD... Would be so wonderfull... At least when you talk about 300 CDs....
Maybe someone has an idea...
Thx alot...
To get the filename as title there is an option to enable in the Preferences window.
Scanning CDs would be not to complicated to do, I'll probably add that in a future version ;)
Guest TX-P
OK
Thank you for the fast reply.... WOW
And yes, didn't see that... :/
YEs, please add that in the future... Would be so lovely... :-)
