Script for CSFD.cz???
bloody.vc
Post by bloody.vc »
Can anybody do a script for CSFD.cz?
Dmitry501
Post by Dmitry501 »
I can :) Please, wait for result.
Dmitry501 wrote:I can :) Please, wait for result.
COOL :-)
Dmitry501
Post by Dmitry501 »
// GETINFO SCRIPTING
// Imports from csfd.cz
// Dmitry501
program Csfd_cz;
  BaseAddress = 'http://csfd.cz/';
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
function GetDirector(Line: string): String;
var BeginPos : Integer;
    result := '';
    BeginPos := Pos('Režie:', Line);
    if BeginPos > 0 then
      Delete(Line,1,BeginPos+5);
      BeginPos := Pos('<br>', Line);
      if BeginPos = 0 then BeginPos := Length(Line);
      result := copy(Line, 1, BeginPos);
      HTMLDecode(result);
      HTMLRemoveTags(result);
  result := Trim(result);
function GetActor(Line: string): String;
    result := '';
    BeginPos := Pos('Hrají:', Line);
      Delete(Line,1,BeginPos + 5);
      HTMLDecode(result);
function GetTitle(Line: string): String;
    result := '';
    BeginPos := Pos('<img src=''/images/flag_52.gif', Line);
      Delete(Line,1,BeginPos-1);
      BeginPos := Pos('</table>', Line);
      HTMLDecode(result);
      MovieName := MovieName + ' (' + result + ')';
      SetField(fieldTranslatedTitle,MovieName);
    BeginPos := Pos(' ', Line);
      Delete(Line,BeginPos, Length(Line));
      result := Line;
      HTMLDecode(result);
function GetCategory(Line: string): String;
    result := '';
      Delete(Line,1,BeginPos + 9);
      result := copy(Line, 1, BeginPos-1);
      HTMLDecode(result);
    SetField(fieldCategory, result);
    result := '';
      Delete(Line,1,BeginPos + 3);
      BeginPos := Pos('<p>', Line);
      HTMLDecode(result);
    SetField(fieldCountry, result);
  LineNr : Integer;
  Line, Value : String;
  BeginPos, EndPos : Integer;
  FilmName, FilmAddr : String;
    LineNr := FindLine('databáze</title>', Page, 0);
    if LineNr = -1 then
        AnalyzeMoviePage(Address);
     LineNr := FindLine('Nebyly nalezeny žádné', Page, 0);
      if LineNr = -1 then
        LineNr := FindLine('<a href="film.', Page, 0);
        if LineNr > -1 then
          PickTreeAdd('Filmy: ' + MovieName, '');
            BeginPos := Pos('<a href="',Line);
            If BeginPos > 0 Then
              EndPos := Pos('">',Line);
              if EndPos = 0 Then EndPos := Length(Line);
              FilmAddr := Copy(Line, BeginPos+9, EndPos-BeginPos-9);
              HTMLDecode(FilmAddr);
              HTMLRemoveTags(FilmAddr);
              EndPos := Pos('<br>',Line);
              FilmName := Copy(Line, BeginPos, EndPos-BeginPos);
              HTMLDecode(FilmName);
              HTMLRemoveTags(FilmName);
              PickTreeAdd(FilmName, BaseAddress + FilmAddr);
              Delete(Line,1,EndPos+3);
          until BeginPos <1;
         If  PickTreeExec(Address) Then
  LineNr : Integer;
    LineNr := FindLine('<div class="nazovfilmu">', Page, 0);
    if LineNr > -1 then
      Line := Page.GetString(LineNr+1);
      HTMLDecode(Line);
      HTMLRemoveTags(Line);
      Value := Trim(Line);
      Line := Page.GetString(LineNr+2);
      Value := GetDirector(Line);
      Value := GetActor(Line);
      SetField(fieldActors, Value);
      Value := GetTitle(Line);
      Value := GetCategory(Line);
    // picture
    LineNr := FindLine('style="padding-left: 10px"', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('<img src="', Line) + 10;
      if BeginPos > 10 then
          EndPos := pos('" width="', Line);
          Value := BaseAddress + Value;
          GetPicture(Value, False);
    // Info
    LineNr := FindLine('id="plot_full"', Page, 0);
    if LineNr > -1 then
      Value := Page.GetString(LineNr+1);
      HTMLDecode(Value);
      HTMLRemoveTags(Value);
      SetField(fieldDescription, Trim(Value));
   // URL
  DisplayResults;
  if CheckVersion(3,4,0) then
    if Input('Import movie from www.csfd.cz', 'Enter the title of the movie:', MovieName) then
			AnalyzePage('http://csfd.cz/index.php?action=hledat&hledej='+UrlEncode(MovieName));
This is BETA ;)
Changed 09/12/2003
bloody.vc
Post by bloody.vc »
can u speak czech? / mluvis cesky, at se pripadne zbytecne nebavime v anglictine? ;-)
THANK YOU FOR A GREAT JOB :-))
little bug i found: in "Country" it imports also "Year" and "Lenght"
Dmitry501
Post by Dmitry501 »
can u speak czech?
No, I speak only on Russian.
Yes, this thus. Server in no way separates these fields. Look itself. Sometimes there are no some values. For example the country, duration. Or year, the country. Or year, the country, duration. In this beta version this problem is not solved. I will possibly make more lately.
bloody.vc
Post by bloody.vc »
ok, thank you anyway :-)
Peca
Post by Peca »
Thank you very much for this script!
vykupitel
THX
Post by vykupitel »
Thank you very much for your work on this script,very helpfull
bloody.vc
Post by bloody.vc »
Dmitry501 wrote:
can u speak czech?
The CSFD.cz changed a little bit and now i see this bug:
error msg: Script error: CSFD_CZ at position 4458 (assigment expected)
Can anybody help?
dmitry
Post by dmitry »
Can anybody help?
Example please. Movie name?
bloody.vc
Post by bloody.vc »
Can anybody help?
For example: Citizen Kane, City by the Sea, Casino, i think every film i tried. Strange thing is that when i tried it yesterday, when one man told me about this error, its doesnt happen to me. Maybe active cash? But few tries later i got this error in 100% of cases.
Yes, the mistake is. I do not use this server, therefore I can not trace change :) . The corrected script look above. :up:
bloody.vc
Post by bloody.vc »
THX :-)))
vykupitel
Question
Post by vykupitel »
How could I change this script to load from WWW only: Translated title, Director, Producer, Country, Actors, Plot? Please help me someone. I don`t want to overwrite my data with this script from csfd.cz. :(
Is there any change to cut year from category?
vykupitel
anyone???
Post by vykupitel »
PLEASE, is there anyone who can help me??? :cry:
What do you want to remove from the script ? Picture and URL ?
vykupitel
RE
Post by vykupitel »
Yes, I don`t want to download pictures,category,year `cos I have it already and the script is always overwite it to me :(
To disable the picture, remove the code between "// picture" and "// Info"
To disable category and year (and others) remove the "SetField(...)" lines that contain the name of the field that you do not want to overwrite.
