New script - Import pictore from "www.sharereactor.com&
Dmitry501
Post by Dmitry501 »
// GETINFO SCRIPTING
// Imports large picture from sharereactor.com
// Dmitry501
program Sharereactor_com;
  BaseAddress = 'http://www.sharereactor.com/';
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  StartPos,EndPos,AddPos: Integer;
    LineNr := LineNr + 9;
    StartPos := pos('<a', Line);
while StartPos > 0 do
    if StartPos > 0 then
      StartPos:=StartPos+8;
      EndPos := Length(Line);
      Line:=copy(Line,StartPos,EndPos - StartPos);
      MovieAddress := copy(Line, 2, pos('">', Line) -2 );
      MovieTitle := copy(Line, StartPos, pos('</a>', Line) - StartPos);
      HTMLDecode(Movietitle);
      PickTreeAdd(MovieTitle, BaseAddress + MovieAddress);
    LineNr := LineNr + 4;
  LineNr : Integer;
    LineNr := 0;
    LineNr := FindLine('Total Matches:', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Total Matches:','');
       AnalyzeMoviePage(Address)
procedure AnalyzeMoviePage(Address: String);
  LineNr : Integer;
  Line, Value : String;
  BeginPos, EndPos : Integer;
  // Picture
  LineNr := FindLine('Click here for a large version', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<a href="', Line);
    EndPos := pos('" target="_blank">', Line);
    Value := copy(Line, BeginPos+9, EndPos - 9 - BeginPos);
    GetPicture(Value, False);
DisplayResults;
  if CheckVersion(3,4,0) then
    if Input('Import picture from sharereactor.com', 'Enter the title of the movie:', MovieName) then
			AnalyzePage('http://www.sharereactor.com/search.php?search='+UrlEncode(MovieName)+'&category=0&submit=Search');
Comment?
It seems to works, thanks :)
kolia
Post by kolia »
Dmitry501 have you updated the script?
it doesn't seem to work any more...
KaraGarga
Post by KaraGarga »
Because ShareReactor was closed 3 or 4 months ago.
ShareReactor.com is offline for the time being. ShareReactor's Owner, Christian Riesen also known as Simon Moon, is under investigation for violation of Copyright and Trademark laws in Switzerland, where he lives and ShareReactor is hosted. There is no date set when its clear if ShareReactor is illegal, or not. No charges have been made yet, this is only an investigation.
If you want to have more information, there is a page open about this (and more) that is updated frequently on http://www.respectp2p.org/
At RespectP2P there are also details in case you want to donate to the legal fund that has been created to aid Christian Riesen in this legal battle.
It's better to exclude this script from AMC script package...
