Small Correction
Bad Joker
Small Correction
Post by Bad Joker »
When using the "search information in internet" button (opens imdb site, or some others) then a browser window will be opened, when no browser windows already is open
but when a browser windows is open, it will use this one (and it's damn shit when u has open a ssl connection or stuff like that)
maybe u can add a option, that you can choose what style the progrmas opens the browser windows, new one or use the open one
would be cool
that's a problem with IE I think.
e.g. Opera 6 & Mozilla 1.0 do not have this problem.
And AFAIK there is nothing that is possible to do to prevent that.
Actually I do the same as what happens when you type an URL into "Start" -> "Run" box.
Twink
Post by Twink »
In Internet explorer options there is a option "reuse windows for launching shortcuts"
Bad Joker
Post by Bad Joker »
where can i find this options???
