Send to?
Mystiqq
Send to?
Post by Mystiqq »
Hi
Im curious that is the 2.05 suppose to support the windows "send to" feature?
Or is there way to make it "easier" to add files directly from explorer window. :/ The drag&drop is great but it would a lot more "flexible" if i could just select file from explorer and send them to the renamer...
Thanks!
Mystiqq
It works with a folder (just put a shortcut to Ant Renamer in the SendTo folder, and right-click on a folder, send to, Ant Renamer), but not yet with files or with more than one folder.
I'll add that later.
