Dupe check warning?
Prophet^^
Dupe check warning?
Post by Prophet^^ »
how about a dupe check warning?
say youre trying to add a new movie which already exists
a warning window pops up stating that movie already exists in number 152
just a thought...im tired of burning the exact same movie more then once :/
oh, and of course there should be an on/off option
well, you can sort movies by name, it will be easy to see that the new movie is the same than an old one...
