Script for startrek.com doesn't work
I think the site has changed....Any script update planned?
Swallie
Post by Swallie »
I have the same problem... and are waiting for an update. im sure it will come... :D
trekkie
Post by trekkie »
Yes Site has changed a lot
I'll try to update the script
Thanks.
Thanks.
Spezi
Post by Spezi »
The site changed long time ago...
Perhaps you could also take advantage of this:
viewtopic.php?t=884
