generating html-page
Charlotte
Post by Charlotte »
I would like that when i generate a html-page of my catalog, that only the movies that aren't borrowed are in this page. So, when a generate the page, i can only see the movies that i have at that moment, i can't see the movies that are borrowed to someone elses.
You have to enable the Checkboxes (Tools -> Preferences -> MovieList), then check only the movies that are not borrowed (select all, right click, uncheck selected, group by Borrower, select group "none", right click, check selected), then in the Export window you have an option to export only checked movies.
