how: 10 pages with 15 movies? (export 2 HTML)
ZoNi
Post by ZoNi »
i would like to export to HTML, but not as one big (or lot small) page, but for example 10 pages with 15 movies on every of them... and all to be linked...
is that possible?
tnx...
Currently it is not possible. It is either one page with all movies, or one page per movie.
ZoNi
Post by ZoNi »
ok... maybe you can add that option in next release? (any idea when it will be finished?)
cheers! :)
if it is available, it will be through scripting
I do not know when it will be finished, since I did not work as much as expected last two months
w0lf
Post by w0lf »
you could just try selecting the number of movies you want in the first page (say 20), exporting them and repeating the same process for the next set of movies and exporting them into another html file and link the files.
just basic hyper-reference. :grinking:
sracer
Post by sracer »
or you could try installing the Paperless Printer virtual driver and using AMC's print function, "print" to html. Here's the link. The virtual driver is free for personal use:
http://www.rarefind.com/paperlessprinter/downloads.html
ZoNi
Post by ZoNi »
sracer wrote:or you could try installing the Paperless Printer virtual driver and using AMC's print function, "print" to html. Here's the link. The virtual driver is free for personal use:
this program seems to be very nice! thanks! :)
