update list + import pictures
michigan
Post by michigan »
*how can i update an existing list?
when i import a new version of my list from origons, it adds all the movies again to the list.
by that i get most movies double in the list. is there a way the program just adds movies that were not in the original list ?
*when i try to import images using one of the pre-made scripts the prgr gives this error : "Socket Error #10060".
or "http/1.1 404Not Found"
although i configured under preferences/use proxy server...
my connection uses a proxy-server.
i checked my firewall and the prgr should be able to connect to the net.
what do i do wrong ?
hope to find some answers and thanks for this great prgr :)
For the origons import, there is nothing for the moment that checks for duplicates, you have to delete manually the movies before import, or only import new ones bu un-selecting the others, sorry :/
For the socket error, it looks like a proxy configuration error... which kind of proxy is it ?
The 404 not found message is maybe a script that does not work anymore, which one was it ?
i have the belgian telenet as provider.
the proxy is http://pac.pandora.be:8080
i saw another post about this in the bug forum.
sorry, but i tested every script so i don't really know anymore which script gave that error.
the update would be a great feature, as i have a very large list and i update it nearly daily at origons.
so for now it's a hell of a job to unmark all the movies.
a job to do when i'm in vacation :)
Anonymous wrote:i have the belgian telenet as provider.
does it work now ? or still not ?
no it doesn't.
i tried by entering the ip instead of the http but no result.
try to enter only proxy.telenet.be (on port 8080)
try proxy.telenet.be on port 8080. that should work.
i tried but no result.
the scripts still won't work :(
