Inserting a "page break" into the text I want into
curna
Post by curna »
Hi, first of all congratulations for this program. It's the best I've found to catalog movies.
Here we go. I wanted the script to copy also the characters in the film, so I changed the script.
The resulting script is:
// Actors
LineNr := FindLine('Cast overview', Page, 0);
if LineNr = -1 then
LineNr := FindLine('cast overview', Page, 0);
if LineNr = -1 then
LineNr := FindLine('Complete credited cast', Page, 0);
if LineNr > -1 then
FullValue := '';
LineNr := LineNr + 1;
if pos('<TD VALIGN="TOP">', Line) > 0 then
BeginPos := pos('">', Line) + 2 ;
EndPos := pos('</TR>', Line);
HTMLRemoveTags(Value);
HTMLDecode(Value);
if FullValue <> '' then
Line := '';
until Line = '';
HTMLDecode(FullValue);
My problem is with this line:
I want each actor + character to be displayed in another row, so I should insert a page break. However, I don't know how to do it.
Thanks for any help. Curna
Curna
Answer
Post by Curna »
Well, you see, I've found the answer in one of the scripts that come with the program.
Thta's the answer.
Yes, that's right ;)
Twink
Post by Twink »
does this one need updating now due the imdb change?
Yes, but I do not remember exactly what it does
Isn't it included already in the IMDB script that comes with the program ?
Twink
Post by Twink »
it displays the actors like actorname (as character)
the current IMDB script already does it already
