socket error 11004
NuRveL
socket error 11004
Post by NuRveL »
hello I'm new at working with ant movie catalog and I have a problem when I try to use the scripts, when I try to connect to get the movie information from IDMB I get the 11004 socket error. I first lookt here on the forum and even on the internet but didn't find annything I could use. And I'm using a proxy and I know you have to do this in
Tools-->preferences-->scripting, and I go's like this proxy.telenet.be gate 8080 but still it won't work. What seem to be my problem? :??:
Which version of Windows do you use ?
It seems that it means that it can't translate proxy.telenet.be to a valid address.
Try with proxy.pandora.be (it is the same server), or directly by specifying the IP : 213.224.83.134
Are you sure that the port is correct ?
