Ahhhh. Willspo's, thats the one...
Anyway... it used to display fine on both local and remote sides, until i added a load more movies and put it online.
I am in the middle of delting everything server side and loading a fresh copy, incase you get a forbidden page...
It will slow down quite a bit for large lists (loading and usage). How many movies are we talking about?
The template is not exactly designed for online usage. If you forgive me the shameless plug: If your webspace has php support, try my template (viewtopic.php?t=813), it looks quite similar to Willspo's because I like his as well.
Hi again...
Actually, I think the plot is the comments field... So forget that one...
Everything is up and running fine, though there is a slight annoyance. For some reason 2 films (beautiful mind, art of war) have multiple categories
Ive tried deleting them in AMC but it keeps bringing them in.
When the files have been updated, what should be transferred to the server??
Me again
ok.. its all uploaded.. and working well (maybe missing images though)
When I make changes to AMC and save it as movies.xml I upload over the old one, but it never changes. I even tried deleting the remote side xml and then uploading it... but same thing... no changes..
