UPD [find duplicates]
velocità di esecuzione migliorata.
I film devono essere in ordine di titolo formattato. 10.000 film con 1.300 duplicati verificati in 30 secondi.
movies must be ordered by formatted title.
improved execution speed.
10.000 movies with 1.300 duplicates tested in 30 seconds.
Authors=Antoine Potten + fulvio53s03
Title=Find Duplicates
Description=Finds duplicate titles in the movie list
Site=
Language=ENG
Version=1.1
Requires=3.5
Comments=2019-12-07 from original ant's script, speed execution implemented by fulvio53s03 | catalog must be ordered by translated + original title.
License=GPL
GetInfo=0
RequiresMovies=1
TitleToUse=3|1|1=Use original title|2=Use translated title|3=Check both titles
IgnoreCase=1|1|0=Case sensitive: Keep the uppercase/lowercase characters as different|1=Case insensitive: Consider "TITLE" as identical to "Title" or "title"
[Parameters]
program FindDup;
  StringUtils1;
  DupList: TStringList;
  quale_campo: integer;
  CurTitle, CurLabel, Curmedia, Cursize: string;
  tipo_confronto, ctr_giri: integer;
  OldLabel, OldMedia, OldSize, OldTitle, NewTitle, ResultPath: string;
  Old_Riga, New_Riga: string;
procedure estrai_dati;
  if quale_campo = 1       then  CurTitle := GetField(fieldtranslatedTitle);
  if quale_campo = 2       then  CurTitle := GetField(fieldOriginalTitle) + ' | ' + GetField(fieldTranslatedTitle);
  if quale_campo = 3       then  CurTitle := GetField(fieldOriginalTitle) + ' | ' + GetField(fieldTranslatedTitle);
  if  tipo_confronto = 1
      then  CurTitle := AnsiLowerCase(CurTitle);      //altrimenti lascio com'era, senza cambiare lettere iniziali
  CurLabel := getField(fieldMedia);
  CurSize  := getField(fieldSize);
  CurMedia := getField(fieldMediaType);
  if ctr_giri = 0 then
         if StringUtils1_Version < 3 then
            ShowMessage('File "stringutils1.pas" is too old, please download a new version of it');
            Error;
            if ResultPath = '' then
               ResultPath := 'f:\duplicates.csv';
               Input('Find Duplicates', 'Store results to:', ResultPath);
//************** primo giro elaborazione ************
     DupList := TStringList.Create;
     tipo_confronto := GetOption('IgnoreCase');
     quale_campo := GetOption('TitleToUse');
     oldTitle := 'mxptlk';          //solo per confrontare primo record
     estrai_dati;
//********* fine primo giro elaborazione ************
    ctr_giri := ctr_giri + 1;
    estrai_dati;
    Old_riga := 'old;' + Oldlabel + ';' + Oldmedia + ';' + OldSize + ';' + Curlabel + ';' + Curmedia + ';' + CurSize + ';' + CurTitle;
    New_riga := 'new;' + Curlabel + ';' + Curmedia + ';' + CurSize + ';' + Oldlabel + ';' + Oldmedia + ';' + OldSize + ';' + oldTitle;
  if CurTitle = oldTitle then
      DupList.Add(Old_Riga);
      DupList.Add(New_Riga);
//  else
//    MovList.Add(CurTitle);
  oldTitle := CurTitle;
  oldLabel := CurLabel;
  oldMedia := CurMedia;
  oldSize  := CurSize;
  DupList.SaveToFile(ResultPath);
provate!
test it!
