Drag & Drop .txt/.nfo
Prophet^^
Post by Prophet^^ »
hey, how about a drag & drop feature for txt's and nfo's?
it would be great if i could just drag & drop my nfo's into the comment area and not have to open the file, select all, copy, close the file, go back to amc, select the area, then paste
just a thought^^
Yes, I should add that ;)
phoenixfr
Post by phoenixfr »
yes wanna be able to store nfos in addition to images and why not txt
