convert the movie title into lower case ?
otreux
Post by otreux »
Is there a way to convert the movie title and the translated title into lower case except the first letter?
Re: convert the movie title into lower case ?
normally the "update fields" script does that, but you said on the other thread that it does not work... depending on what does not work I can maybe help
otreux
Post by otreux »
when I launch Update Field and choose the correct option, I get a new window with some info, click on Ok and nothing happens. I do not understand :(
Did you select the movies to process, or specify to process all movies (using the options at the bottom right) ?
otreux
Post by otreux »
I have select some movie and launch the script
spiacente ma per avere aiuto devi fornire più informazioni:
- quali opzioni ha scelto nell'esecuzione dello script? :??:
- qual'è il campo (rispetta maiuscole e minuscole originali) da "convertire"?
sorry but tor help you we need you provide more informationa:
- what options did you choose in the script execution? : ??:
- what is the field (please respect the original upper and lower case) to be "converted")?
otreux
Post by otreux »
Ciao :)
In opzioni di esecuzione ho spuntato la prima e la terza opzione, nelle opzioni dello script ho tutti zero tranne ChampCasse che è sul 4
Nei campi modificabili ho spuntato solo Titolo originale e Titolo tradotto. Lancio la script, seleziono "Change letter format with option", mi esce una scritta che mi avvisa delle varie possibilità, posso cliccare solo OK, NO ed Interrompi. Io clicco su OK ma non succede niente
Hi
In execution options I ticked the first and third options, in the script options I have all zeroes except ChampCasse which is on 4.
In the editable fields I have checked only the original title and translated title. I launch the script, select "Change letter format with option", I get a message that warns me of the various possibilities, I can only click OK, NO and Stop. I click on OK but nothing happens
otreux
Post by otreux »
fantastic, thanks :)
daws0n
Post by daws0n »
could you upload this script again please?
