import only the rate from imdb.com?
otreux
Post by otreux »
Hi:)
does anyone know how to create an operation that AMC import ONLY (without modifying all other information present) the rate from IMDb automatically of all the films in my archive without my confirm every time?
Re: import only the rate from imdb.com?
If you uncheck all other fields and enable the right "batch mode" option, it should work
otreux
Post by otreux »
ops I had not seen the option ... thanks :p
