I have quite a few vhs tapes that I have recorded over the years. Some of these tapes have more than one movie on them. Is it possible to use the same number for more than one movie, or do I need to renumber my entire tape library using a different number for each movie?
Thanks.
Steve
Use same number for more than one movie
greg
It's possible (by modifying script or the file) but it is not recommended.
Some functions are based on the film number (for example the management of the loans, export, and maybe reports).
In the next version there will be the possibility to add a field "Number of disc/tape" for this kind of things.
Lexus
Thanks, That would be great. Any idea when you might add this? I certainly don't want to complian, because I use your software alot. I have a bunch of disks with multiple titles and want organize/catalog them by number. So it would help if I could use the same number for the disks that have more than one title.
Thanks for the great program!
