Update Script
Update Script
Update italian Script Please. Thank You
Re: Update Script
It could be useful to provide a little more details, e.g. which script?
Also, have you already tried to run the "update scripts" script from the top of the scripts list, in case a newer version of the script you want to use is available?
Re: Update Script
Hello, unfortunately always check but all Italian scripts are no longer updated
Re: Update Script
@catozzo29:
devi indicare quali script son in errore e dire anche qual'è l'errore che riscontri, altrimenti hai poche (nulle) speranze che qualcuno corregga gli errori.
you must indicate which scripts are in error and also say what is the error you are experiencing, otherwise you have little (no) hope that someone will correct the errors.
