Post
by Guest » 2003-07-29 09:30:33
Have you thought to develop a PocketPC version of Ant Movie?
zion
Posts: 19 Joined: 2002-05-30 14:35:24
Post
by zion » 2003-07-29 13:56:04
antp has already not enough time to develop amc 4.0 so a PocketPC version is more unlikely to happen... But maybe after the 4.0 version if it's really under GPL someone will want to port it to PocketPC
Posts: 9869 Joined: 2002-05-30 10:13:07
Post
by antp » 2003-07-31 14:52:54
The problem is that there is not Delphi equivalent for PocketPC, I think
zion
Post
by zion » 2003-08-01 13:24:23
Erhm, you're wrong antp, you could develop it using .NET
Post
by antp » 2003-08-01 13:55:39
Compile a .NET thing on PC and put it on WinCE ?
Why not, but somebody will have to give me a PocketPC so I can try it
Chak
Post
by Chak » 2004-06-13 21:17:48
For the time being you can use the export function and import it in ListPro.
The only thing that you will miss are the pictures
zandal
Post
by zandal » 2005-06-22 21:23:17
Can i test it for u....
Post
by antp » 2005-06-23 07:50:25
Now I have a PocketPC (this post was 2 years old), but it seems that it is not possible to make PPC applications with Delphi.NET
