Problems with ogm format files
When using "Get Information" & "From File", ANT Movie Catalog doesn't seem to recognise ogm format of files. This could also apply to mvk formats as well (but I haven't tested).
Any advice?
I only implemented AVI in the program.
I'll add OGM and MKV in a future version.
Thanks antp,
Your program is pretty damn cool. With the ability to process ogm/mkv formats then it will be indispensable. Don't want to put pressure on you but please hurry with the new version.
Cheers
Anonymous wrote:please hurry with the new version.
Sorry but I can't "hurry", I work on this program when I have time and when I want to work on it ;) That's also for this reason that it is freeware ;)
That's a fair comment and I note the fact your program is provided as freeware.
Cheers
