There's no number 1
boristhecat
There's no number 1
Post by boristhecat »
For some weird reason there's no number 1 in the listing now. The first listing is number 2. Why on earth would that be?
Re: There's no number 1
Maybe you deleted it or changed its number?
Or the sort order is different and it is elsewhere?
Or it is hidden by one of the filtering options? At the bottom, it shows total number of movies and how many are visible
