Export -Sort ... Reverse?
RoughlyRandom
Post by RoughlyRandom »
Hi AntP,
First (as almost everyone starts their first post) thanks for a stunning program!!!
I tried almost every DVD cataloging program out there and couldn't find one I liked ... until yours :)
I do have one question though, I use the export function a lot (HTML, SQL and CSV (so I can convert it to a format I can read on my Palm)
Is it possible to reverse the sort order of a selected field? (I'd like to list it in reverse date order so the newest ones are at the top... I can't seem to be able to do it (wellnot unless I use mysql and php to view it)
unfortunately it is not possible : when I add the sorting thing I forgot to include it, and since it is not easy to modify in current version I leave that until version 4.
For the CSV you can open it in Excel (or similar) and sort the data on the columns you want ;)
