Script Cineol no funciona (doesn't work)
spanishipo
Post by spanishipo »
Hola. Llevo años usando este catolgador y en especial el script de Cineol pero no ha vuelto a funcionar da error siempre al buscar la informacion de la pelicula.
IOHandler value is not valid.
A ver si es posible hacer uno nuevo que funcione otra vez.
Muchas gracias.
Re: Script Cineol no funciona (doesn't work)
That error means that the site is redirecting to HTTPS, and AMC does not support that redirection.
So the script has to be updated to directly use the HTTPS version of the site.
Maybe the changes are easy to do, but someone will have to take some time to check that.
spanishipo
Ok, thanks
Can anybody do this script, please?
Thank you.
