Move Movies and 2 different languages?
TheOne
Post by TheOne »
First of all, I think your program is the best one to collect my movies but I missing some really need functions.
The first is:
I sort my movies with numbers. Your programm also supports this func. but I can't move the movies easy up and down to change these numbers.
I hope you anderstand my problem. I would like to change these numbers
with a drag and drop operation. Is it possible to add such a func.?
The second problem is:
I have some movies in different languages. But your Programm only allows me to input one language. Is it possible to create a texfield where you can input different languages?
I have the same problem with the subtitels. I hope someone can help me.
Hi
For the number change, it will maybe be more easy in next version, but I do not promise anything yet.
For the multiple languages, just put more than one language in the field, e.g. "English, French". For the moment nothing else can be done.
Maybe it will be improved in next version, maybe later.
