"Could not load SSL library"
e_nan0
Post by e_nan0 »
Hola a tod@s,
soy nuevo aqui, y estoy intentando utilizar AMC en Ubuntu 16.04 LTS
pero cuando intento utilizar el script (me aparece el error
que he puesto en el título, con lo que no conecta con la página seleccionada
(filmaffinity en este caso, aunque no funciona con ninguna)
Alguien sabria decirme por donde tirar?
Muchas gracias de antemano
Re: "Could not load SSL library"
Check that you have libeay32.dll & ssleay32.dll in the same folder as MovieCatalog.exe and that you use the versions provided with the program version that you use.
e_nan0
Post by e_nan0 »
Thx. I think the problem were when I tried to run AMC from a link in the desktop.
I've tried to run it directly from the folder itself, and it worked fine.
Thx again for your response.
