New Spanish Script for Yahoo!Cinema
folgui
Post by folgui »
Hi!
This is my first script, not full, but really worked on it :)
Originally script is from Andrea Cristaudo, and comes with AMC pack.
Spanish database pages are a bit different from italian one, so i need not only to change strings, also work on checks, ...
Sure, some bugs, but i tried it with several movies and no problems. If any, tell me. Also, optimizations i can do for it are welcome.
Sorry if my english isn't 100% ok ;)
Here's the script, i named file as: Yahoo Cinema (ES).ifs
// GETINFO SCRIPTING
// Yahoo!Cinema (Spanish) v1.1
* Movie importation script for:                   *
* Yahoo!Cinema (ES), http://es.movies.yahoo.com   *
* (c) 2003 Andrea Cristaudo achris@tiscalinet.it  *
* Updated for Spanish Database support and more   *
* info importing by folgui (folgui@bigfoot.com)   *
* For use with Ant Movie Catalog 3.4.3            *
*  www.antp.be/software/moviecatalog              *
*  This program is free software; you can         *
*  redistribute it and/or modify it under the     *
*  terms of the GNU General Public License as     *
*  published by the Free Software Foundation;     *
*  either version 2 of the License, or (at your   *
*  option) any later version.                     *
program YahooCinema;
LargePic = True; // Import Large Picture
TheMovieAddress: string;
result := -1;
if StartAt < 0 then
  StartAt := 0;
   result := i;
  InitialPos: Integer;
  InitialPos := Pos(EndTag, S);
  Delete(S, 1, InitialPos + 1);
procedure AnalyseLargePicPage(Address: string);
LineNr: integer;
ImageURL: string;
LineNr := FindLine('<img src="http://eur.news1.yimg.com/eur.yimg.com/', Page, 0);
If LineNr <> -1 then
  ImageURL := TextBetween (Line, '<img src="', '"');
  GetPicture (ImageURL, False);
LineNr: integer;
BeginPos: integer;
LineNr := FindLine('<font face=arial,helvetica size=+1><b>Resultados de búsqueda</b></font>', Page, 0);
if LineNr = -1 then
  AnalyzeMoviePage(Page);
  AddMoviesTitles(Page);
  if TheMovieAddress='' then
 Fine: Integer;
 EndActors: Integer;
 EndProducers: Integer;
 EndMusics: Integer;
 EndDirectors: Integer;
 EndPhotographers: Integer;
 EndWriters: Integer;
 EndRating: Integer;
 strActors: string;
 strComments: string;
 strProducers: string;
 strMusics: string;
 strDirectors: string;
 strPhotographers: string;
 strWriters: string;
 strTemp: string;
 ImageURL: string;
 BeginPos, EndPos: Integer;
 Field: integer;
 irate: integer;
Page.Text := StringReplace(Page.Text, ' ', '');
Fine := 0;
  LineNr := FindLine('<FONT color=white face="arial, helvetica"><b>', Page, 0);
if LineNr > -1 then
  //Translated Title
  HTMLRemoveTags(Line);
  Line := StringReplace(Line,'"','');
  SetField(fieldTranslatedTitle,Line);
   LineNr := LineNr + 1;
   //GetPicture of Movie
   if Not LargePic then
    // Import Small Picture
      if pos('html"><img src="http:', Line) <> 0 then
        Delete(Line, 1, pos('<img ', Line) + 9);
        Delete(Line, pos('" border=', Line), pos('</a>', Line) + 1);
        GetPicture(Line, False);
      if pos('Agrandar la imagen</a>', Line) <> 0 then
        ImageURL := TextBetween(Line, '<a href="', '">Agrandar la imagen</a>');
        AnalyseLargePicPage('http://es.movies.yahoo.com' + ImageURL);
   //Original Title
   if pos('<b>Título original:</b>', Line) <> 0 then
     Delete(Line, 1, 16);
     SetField(fieldOriginalTitle, Line);
   //Country and Year
   else if pos('<b>País y año:</b>',Line) <> 0 then
     SetField(fieldCountry, Line);
     SetField(fieldYear, copy(Line, 2, 4));
   //Category and Length
   else if pos('<b>Género:</b>', Line) <> 0 then
     Delete(Line, 1, 7);
     SetField(fieldCategory, Line);
     Delete(Line, 1, 9);
     SetField(fieldLength, copy(Line, 1, 3));
     If GetField(fieldLength) = '' then
      SetField(fieldLength, copy(Line, 1, 2));
   //Rating
   else if pos('<b>Crítica:</b>', Line) <> 0 then
     irate := 0;
     EndRating := pos('<img src="http://eur.i1.yimg.com/eur.yimg.com/i/de/mo/1sg.gif" width=10 height=9>', Line);
     while EndRating = 0 do
       irate := irate + 1;
     SetField(fieldRating, IntToStr(irate*2));
   //Description
   else if pos('<b>Sinopsis:</b>', Line) <> 0 then
     LineNr := LineNr + 2;
     HtmlRemoveTags(Line);
     SetField(fieldDescription, Line);
   //List of Actors
   else if pos('<b>Actor / Actriz:</b>', Line) <> 0 then
     strActors := '';
     EndActors := pos('</font></td></tr>', Line);
     while EndActors = 0 do
       if strActors = '' then
        strActors := Line
        strActors := strActors + ' ' + Line;
     SetField(fieldActors, strActors);
   else if pos('Montador:</b>', Line) <> 0 Then
     strComments := 'Montaje: ' + Line + #13#10;
   // Music for Comments
   else if pos('<b>Musica:</b>', Line) <> 0 then
     strMusics := '';
     EndMusics := pos('</font></td></tr>', Line);
     while EndMusics = 0 do
       if strMusics = '' then
        strMusics := Line
        strMusics := strMusics + ' ' + Line;
     strComments := strComments + 'Música: ' + strMusics + #13#10;
   // Aditional Music Author for Comments
   else if pos('<b>Compositor (música adicional):</b>', Line) <> 0 then
     strComments := strComments + 'Compositor: ' + Line + #13#10;
   //Director
   else if pos('<b>Director:</b>', Line) <> 0 then
     strDirectors := '';
     EndDirectors := pos('</font></td></tr>', Line);
     while EndDirectors = 0 do
       if strDirectors = '' then
        strDirectors := Line
        strDirectors := strDirectors + ' ' + Line;
     SetField(fieldDirector, strDirectors);
   //Photography for Comments
   else if pos('<b>Fotografía:</b>', Line) <> 0 then
     strPhotographers := '';
     EndPhotographers := pos('</font></td></tr>', Line);
     while EndPhotographers = 0 do
       if strPhotographers = '' then
        strPhotographers := Line
        strPhotographers := strPhotographers + ' ' + Line;
     strComments := strComments + 'Fotografía: ' + strPhotographers + #13#10;
   //Screenplay Writer for Comments
   else if (pos('<b>Guionista:</b>', Line) <> 0) Or (pos('<b>Guión', Line) <> 0) then
     strWriters := '';
     EndWriters := pos('</font></td></tr>', Line);
     while EndWriters = 0 do
       if strWriters = '' then
        strWriters := Line
        strWriters := strWriters + ' ' + Line;
     strComments := strComments + 'Guionista: ' + strWriters + #13#10;
   //Producer
   else if (pos('<b>Producción:</b>', Line) <> 0) Or (pos('<b>Productor', Line) <> 0) then
     strProducers := '';
     EndProducers := pos('</font></td></tr>', Line);
     while EndProducers = 0 do
       if strProducers = '' then
        strProducers := Line
        strProducers := strProducers + ' ' + Line;
     SetField(fieldProducer, strProducers);
   // More Comments
   else if pos('<b>Notas de Producción</b>', Line) <> 0 then
     strTemp := TextBetween(Line, '<FONT face=arial size=-1>', '<a href="');
     HtmlDecode(strTemp);
     strComments := strComments + '------------------------------';
     strComments := strComments + #13#10 + strTemp;
   // More Comments
   else if pos('<b>Crítica</b>', Line) <> 0 then
   else if Line = '</html>' then
    Fine := 1;
  until Fine = 1;
  SetField(fieldComments, strComments);
DisplayResults;
NewLineNr: Integer;
TheMovieAddress := '*';
LineNr := 0;
LineNr := FindLine('<font face=arial,helvetica><b>Resultado de películas</b>',Page,LineNr);
LineNr := LineNr + 3;
PickTreeAdd('Resultados encontrados:','');
while LineNr > 2 do
  BeginPos := pos('<li><a href="',Line)+13;
  EndPos := pos('">',Line);
  MovieAddress := copy(Line,BeginPos,EndPos-BeginPos);
  Delete(Line,1,EndPos + 1);
  BeginPos := 1;
  EndPos := -1;
  MovieTitle := Line;
  HTMLRemoveTags(MovieTitle);
  HTMLDecode(Movietitle);
  NewLineNr := FindLine('<li><a href="',Page,LineNr+1);
  if NewLineNr <> (LineNr + 1) then
   LineNr := 2
   LineNr := NewLineNr;
  if TheMovieAddress='*' then
   TheMovieAddress := MovieAddress
   TheMovieAddress := '';
if CheckVersion(3,4,0) then
  if Input('Yahoo!Cinema España', 'Introduce el título de la película (enter movie title):', MovieName) then
   AnalyzePage('http://es.search.movies.yahoo.com/search/movies_db_es?mt='+UrlEncode(MovieName));
Thanks, it will be included in the next update ;)
folgui
Post by folgui »
Above script modified.
Now, no problems with number of digits in length of movies.
Deleted lines that wasn't neccesary. Now OK i think.
Thanks Antoine for this great program ;)
folgui
Post by folgui »
Hello!
Here's another spanish script, there isn't only culturalia :)
No reply since time ago. Perhaps, need some update or get more info, if possible. Or some checks to confirmate working successfull.
Available on the last scripts pack from antp, with date 01-09-03.
Only to remember it if someone doesn't know it.
Perhaps, some advantages above culturalia, it that imports "Length" of movie and has some movies culturalia doesn't like "La Bella y la Bella 2".
Regards, folgui.
KaBeCi
Post by KaBeCi »
just to reply.. the script works fine, may be you havent received any reply because a script for Yahoo Cinema (ES) is useless
why people will get info from a spanish site if it doesnt have any description/summary/quote of the movie? that's why I (and i think most of spanish talkers here) use the Culturalia script, to get the spanish description.
homeroarg
Need Some Help
Post by homeroarg »
Can anyone with skills (that is why i can not do it) modify this script to make it batch and to let me choose what is going to be imported, like in the IMDB batch script ?!? I want to import the translated title, the actors and the description but i don't want to change the pictures....
I think it shouldn't be too hard, i hope someone can give me a hand with this. :wink:
The easiest way to block some fields from being modified is to edit the script and put a "//" in front of the lines that do not have to be executed.
The lines that modify fields are those that contain a call to "SetField", and the line that sets the picture contains "GetPicture".
homeroarg
Post by homeroarg »
Found that just after hitting "Submit".... :p
Hello!
Script updated (1st message of thread) with a few changes:
- Possibility of importing the large picture that Yahoo!Cinema offers. By default, the script imports it.
- Obtains more info from page than before, like rating, full list of actors, musicians, photographers, writers, producers, ...
Just check it.
Regards, folgui.
folgui
Post by folgui »
Hello!
One day after previous update, another one ;)
- It gets now more info for comments, from "Notas de Producción" and "Crítica".
- Also fixes some movies where Screen Writer and Producer headings appear in different ways and that info wasn't added.
Regards, folgui
Dinamitic
Me da error (It give me this error)
Post by Dinamitic »
Error de seqüencia: YAHOOCINEMA en posicion 10993 (unknow identifier: STRTEMP)
Corresponde a la sequencia de la linea numero 367 con el texto: "strTemp := TextBetween(Line, '<FONT face=arial size=-1>',...."
Alguna idea?
Error del script? o mio?
micmic
Post by micmic »
Script mistake. Change this:
 Fine: Integer;
 EndActors: Integer;
 EndMusics: Integer;
 EndRating: Integer;
 strActors: string;
This is correct (new: variable definition):
 Fine: Integer;
 EndActors: Integer;
 EndMusics: Integer;
 EndRating: Integer;
 strTemp: string;
 strActors: string;
folgui
Post by folgui »
Hello!
A bug introduced in the latest modifications :/
I've been on christmas holiday's, so thanks micmic :grinking: for answering and fixing the problem.
Script of first message of this thread, already fixed.
Regards, folgui
micmic
Post by micmic »
;) Not at all
