Error: Cannot find FRuser.hlp file (newbie)
Jeri
Post by Jeri »
eGreetings,
Thank you for such great software!
Question:
When I click on Print/Designer and then on the "?" to access the help file for the Designer I get an error message:
Cannot Find The FRuser.hlp file. Do You Want To Find It Yourself?
I have downloaded the separate Help & Language .zip file but it was not in there and I have ran a search on my hardrive. I just can't find it.
Any assistance would be greatly appreciated.
Thank you very much for your help and expertise.
Kind Regards,
Jeri
Thanks ;)
I did not include this file because it was made for all functionnalities of the Report Designer (this is a program made by someone else than me), and lots of these functionnalities where unused in AMC.
A small tutorial about reports is in the help file of AMC (english.chm).
Jeri
Post by Jeri »
Wow! Thank you for your speedy reply! :grinking:
Kind Regards,
Jeri
