Help with script - substring needed
rs232
Post by rs232 »
I have been using a script to generate .NFO for long time now.
Basically it saved the full IMDB url in the URL field.
I now moved from Plex to Emby (about time) and emby required the .nfo to contain something like this:
<imdbid>ttxxxxxxx</imdbid>
Considering I can get the full URL easily with this:
      FormatedData := FormatedData +'   <imdbid>'+GetField(fieldUrl)+'</imdbid>'+#13#10;
Which gives me this:
<imdbid>https://www.imdb.com/title/tt0085400</imdbid>
How would I go extracting the tt0085400 reference only instead than the full URL?
The sources can be either called e.g.:
https://www.imdb.com/title/tt0085400/?ref_=fn_al_tt_2
or
(two type of URL format are saved as far as I can tell)
Thanks!!!
Re: Help with script - substring needed
Check the bottom of the IMDb script: it does that in case the movie URL is provided
