How do I change the content of Description Field
Magdalena50
Post by Magdalena50 »
Since updating to the 4.2.2(BETA) version of the Ant Movie Catalog, the Description Field only enters about one line of actual movie description (but masses of entries about Award nominations which I do not want) Also the 'tagline' from the movie I do not need.
Is there a way of altering this field (I use IMDB to get the info)- so it is a permanent setting. Thank you for any suggestions. :grinking:
Re: How do I change the content of Description Field
On the right of the scripts list there are options for the currently selected script: double-click on one of them to change it.
In case of IMDb, you have "Awards" and "GetTagline" options.
These already existed in earlier versions of the script so I am surprised that you only are concerned now by that, especially since by default the awards are not enabled :??:
For the description, if you change "DescriptionSelection" in some cases you may get a longer one (depending on the movies).
