exporting to csv
jagie
exporting to csv
Post by jagie »
when i want to export to csv, there are no available fields visble, so he exports an empty csv
Re: exporting to csv
What do you mean by "no available fields"?
Field names are either in "Available fields" list or in "Fields to export".
If both lists are empty, it may be just a screen refresh error/glitch, you can try passing another window in front of that one, or resize it, to force it to refresh.
jagie
Post by jagie »
Thanks for the fast reply
But still have the same problem,in the export window i don't see any field names in "Available fields" list or in "Fields to export"
neither after resizing or passing another window in front of it.
It is weird, I don't really have an idea of what could cause that
Does it have the same problem when selecting SQL for example?
(as both use the same style of fields lists)
jagie
Post by jagie »
Yes it have the same problem when selecting SQL.
I just installed version 4.2.2.1 and still the same problem.
The arrow "add all" aparentlyI works, so I just export them all
and delete those i don't need in the generated CSV-file.
You can also find prefs.xml in c:\programdata\ant movie catalog (if I remember well) : in that file you find all saved settings.
In the node Settings/Export/CSV/Fields you find the list of fields included: you can remove from there those you don't want, now they were all added.
