Filmaffinity - búsqueda limitada / short searching
AARON8888
Post by AARON8888 »
Hola
Tengo última versión amc y uso última versión script Filmaffinity.
Cuando busco títulos como estos: Red [2010] o Big [1988], los resultados son muchos pero al final se queda corto y no llega al título que busco.
¿Hay alguna manera de aumentar los resultados o de limitar la búsqueda con la palabra que buscas?
¿Quizá poniendo alguna regla o signo ortográfico en el campo de búsqueda sin tener que modificar el script?
Gracias de antemano. :)
Hi!
I have last version amc, using last version of filmaffinity as well.
When I try to search titles like Red [2010] or Big [1988], then lots of results and limited of time, without my expected title.
Is there any posibility to increase searching of time or put a limit search with the only requested word(s)?
Maybe not necessary to amend script, just to write along the requested word any orthographical simbol?
Thanks in advance.:)
Re: Filmaffinity - búsqueda limitada / short searching
The script just fetches data from the site, so it is a limitation of their own search engine:
https://www.filmaffinity.com/es/search.php?stext=red
I'm not sure what you mean by "increase searching of time" though :??:
AARON8888
Post by AARON8888 »
Thanks antp for your reply.
As you say script just fetches titles ordered by year which is more useful or practical.
Option to fetch "ordered by relevance" would be a great option as well. If like this, "Red" was in 19 position, and 'Big" in 4 position.
Searching "Red" [2010] --> 534 titles found (including the original title).
Script only provides 150 titles (I don't remember figure now) ordered by year.
Same matter with "Big" [1988] --> 494 titles found.
That is what I meant with ""increase searching of time".
Then, I think script can be modify to fetch all results, instead first 150 titles. I don't know.
Awaiting yours and I appreciate your help. :)
AARON8888 wrote: 2018-10-07 08:30:36 As you say script just fetches titles ordered by year which is more useful or practical.
There are options on the right of the script window: double click on "SortByYear" option to disable it and then order by relevance (though that it seems to be the default option)
AARON8888
Post by AARON8888 »
Thanks a lot.
I will check tonight, and I will let you know if I get it.
Regards
AARON8888
Post by AARON8888 »
Hi!
Really awesome useful "Script option". Lots of options:
See below screenshot:
https://snag.gy/KuNpI0.jpg
Thanks for your guidance and have a good day! :)
