Error se cierra el programa
sergi73
Post by sergi73 »
Hola, tengo la version 4.2.2 BETA y el programa se cuelga constantemente, tengo que forzar el cierre y volver a abrirlo. Alguien sabe a que se debe? Utilizo Windows 10. Habria alguna version del programa mas reciente? Muchas gracias
Hello, I have the BETA version 4.2.2 and the program is constantly hanging, I have to force the closure and reopen it. Does anybody know what is it due to? I use Windows 10. Would there be any version of the most recent program? Thank you very much
Re: Error se cierra el programa
At what moment does it "hang"? i.e. what operation are you doing when it happens?
sergi73
Post by sergi73 »
a veces cuando estoy descargando informacion desde un script, o simplemente al pulsar la ficha de una pelicula. he desinstalado el programa y vuelto a instalar y sigue haciendo lo mismo
sometimes when I'm downloading information from a script, or just clicking on the tab of a movie. I have uninstalled the program and reinstalled and continue doing the same
Strange, I don't recall a report about such problem recently; I don't think that Windows 10 is the cause, it must be due to something else (or in combination with something else).
sergi73
Post by sergi73 »
no se, seguire investigando y si encuentro la causa lo escribire en el foro. por cierto, vamos a tener alguna actualizacion para el programa?
I do not know, I will continue investigating and if I find the cause I will write it in the forum. By the way, are we going to have an update for the program?
I should release a 4.2.2 "final", but it will be the same as the 4.2.2 beta just not labelled as beta any more.
No new features planned.
sergi73
Post by sergi73 »
ya esta disponible la version final? muchas gracias
Is the final version available? thank you very much
When I say I should release a 4.2.2 "final" it means I have not done it yet.
But as I said, the final will be the same as the beta, only the label in the title will change.
sergi73
Post by sergi73 »
Ok, muchas gracias
Ok thank you very much
