add a number at the beginning of the line?
otreux
Post by otreux »
Is it possible, using a script, to add a number (without deleting the field) at the beginning of the Source field?
For example, I have in the source field:
Eastwood Clint
I want:
1 - Eastwood Clint
the problem is that, for reasons of space, I had to divide my film collection into 2 Hard disk and I would like to put a number in front of the actor / director's name to quickly find out what Hard Disk is in
Re: add a number at the beginning of the line?
You just want to add a "1" in front of the field for all selected movies?
You can do this:
program newscript;
  SetField(fieldSource, '1 - ' + GetField(fieldSource));
otreux
Post by otreux »
PERFECT...thanks :)
