Hello!
Are there any plans for adding support for extracting information from bluray discs automatically? For entering bluray discs information I use copy/paste from BDInfo, but honestly speaking this is a bit tedious procedure, so it seems to me that such a feature would be great.
Best regards
Extracting information from bluray discs
Yoan
Re: Extracting information from bluray discs
blu-ray discs are most of the time protected. MediaInfo can retrieve info from unprotected ones, but for the others I'm not sure it is so simple.
Which BDInfo do you use? (I find at least two software with that name)
Does it have an interface to be used from another program? (as for sure I won't rewrite the code for doing that
