FilmAffinity 3.03 error IOHandler value is not valid
masterchipo
Post by masterchipo »
Hello friends, the Filmaffinity script does not work again.
It is script 3.03, and when importing an error message comes out, it says: Error IOHandler value is not valid: Incoming picture from internet
Regards
masterchipo
Re: FilmAffinity 3.03 error IOHandler value is not valid
They modified the HTML tag that the script uses to find the picture address, so it could not find it.
The script has been updated on the server to version 3.04
masterchipo
Thank you. The problem is solved
masterchipo
