Can't print
lepujau
Can't print
Post by lepujau »
Just downloaded 4.2.2 but when I click on print I get an error message that says:
Error reading frreportForm: Access violation at address 0072D475 in module 'Moviecatalog.exe' Read of address 00000030
I've never seen this before. Anyone knows what is going on?
Re: Can't print
Have you tried with another template or to another printer? (e.g. a virtual PDF printer)
lepujau
Re: Can't print
Post by lepujau »
Thanks for the suggestion but I've found the problem. My PC was updated last night and it changed the default printer. As a result when the pgm searched for a printer it couldn't find one. Changing the defaut printer to a (proper) printer did the trick.
Thanks anyway.
Re: Can't print
Thanks for the info, if others have the problem I can suggest them to check that :)
(and maybe I could also fix the bug in the program, if the printer is not available notify the user and take the default one :D )
