Hello,
plz can u fix imdb script, description or plot is not getting it completed it only gets the first line then it gives you three dots...
thanks for any hepling.
imdb, plot description fix
Re: imdb, plot description fix
For which movie for example?
Have you set "DescriptionSelection" to long instead of short, in the options on the right? (double click on it to change)
raeditani93
It worked.
Thanks.
Thanks.
AnthonyB
Actually, I'm hitting the same issue, but only with 1 movie (so far).
I'm using AMC 4.2.2.1 and IMDB script v4.012.
I already had the DescriptionSelection setting on Long.
The movie I am hitting this issue with is https://www.imdb.com/title/tt4538916/
What I am getting scraped is:
what I should be getting is
On the eve of retirement a middle class, judgmental snob discovers her husband has been having an affair with her best friend and is forced into exile with her bohemian sister who lives on... See more »Code: Select all
On the eve of retirement a middle class, judgmental snob discovers her husband has been having an affair with her best friend and is forced into exile with her bohemian sister who lives on an impoverished inner-city council estate. -
I get the first result, but it is strange that I get it without the "see more" and the end if you have it.
There is no long description on https://www.imdb.com/title/tt4538916/reference so that's normal to only get the first one though.
An option should be added to fetch an extra page for full summary; I think it existed before but was removed in the last big changes of the site/script.
