[UPD ITA] FilmUp.it version 2.0
Nuova versione, funzionamento verificato con i film:
New version, movies used to test:
Assassinio Sull'orient Express
Inju, La Bête Dans L’ombre
Avatar
Blade Runner
Bride Wars - La Mia Migliore Nemica
La Prima Cosa Bella
Magnolia
Un Dollaro D'onore
Pronti A Morire
Alien: Covenant
Blade Runner 2049
Arrival
Mamma Mia!
Aggiornate lo script usando l'apposita procedure "Script Update" poichè esso contiene dei caratteri speciali che non tutti gli editors/browsers traducono correttamente!
Update Script using procedure "Script Update" as it contains some special characters not always well translated by editors/browsers ! ;)
Re: [UPD ITA] FilmUp.it version 2.0
Should it replace the current script? Or is it still in testing phase?
If it should replace, can you send me the original file via https://ks3c.antp.be/upload.php as I'm not sure that there aren't some special characters lost when copy/pasting it from the forum.
antp wrote: 2018-05-24 16:43:40 Should it replace the current script? Or is it still in testing phase?
It must replace old script version 1.x.x.
Sent to h__ps://ks3c.antp.be/upload.php !
thanks.
Maybe it was fine for special characters, what I took for a wrongly encoded/decoded character was just the "l?" that you replace after other special ones.
Normally most of these characters are correctly decoded by UTF8Decode, why did you do that via a series of StringReplace here?
Only a few special ones normally require that.
antp wrote: 2018-05-24 18:10:19 Thanks :)
I don't really know the reason why :shaking: :innocent: it happened that some characters were non well translated... maybe for a previous error in working on string... (surely my fault)... :fire:
otreux
Post by otreux »
Fantastic, thanks! :clapping:
