[ITA] FilmUp.it updated
Authors=L. Francisco, Pivello, Zandal, Fulvio53s03
Title=FilmUP
Description=Get movie info from Leonardo.FilmUP.it and shows years in picklist (Fulvio53s03)
Site=http://filmup.leonardo.it
Language=IT
Version=1.1.3 - 05.05.2018
Requires=3.5.1
Comments=29.12.2011 Commenti estratti sia per vecchio che per nuovo layout di pagina
License=
RequiresMovies=1
AlternateURL=0|0|0=Use the FilmUP web site for FieldURL|1=Try to use ufficial movie web site for FieldURL
MezzoVoto=1|1|0=Integer Ratings|1=Ratings with ,5
ActorsPlusCast=0|0|0=Get Main Actors data (if present) otherwise get Cast field|1=Get Main Actors data (if present) and Cast data
TrailerURL=0|0|0=Normal URL page|1=Trailer URL page (if found)
Poster=0|0|1=Download full-res Poster|0=Download tiny Poster
[Parameters]
program LeonardoFilmUP;
  StringUtils7552;
  debug_search = false;                          // debug mode on/off
  Apice       = #39;
  folder = 'f:\prova\';                                   // directory where to save files
  MovieName, MovieToSearch, MovieTitle: string;
  Pagina_Ricerca, TheMovieAddress, Pagestr: string;
  SaveComm, comm, save_translated, Save_original: String;
  accento: string;
  lgth_title: integer;
function DecodePage(s: string): string;
  s := StringReplace(s, '’', '’');
  s := UTF8Decode(s);
  Result := s;
  LineNr: integer;
  BeginPos: integer;
  campo_ricerca: string;
  Pagestr := Page.Text;
  Pagestr := DecodePage(Pagestr);                //2018.04.30fs      qui da correggere ?  in apostrofi
  if debug_search then
     DumpPage(folder + 'FilmUP_page.txt', pagestr);                //2018.04.30fs
  LineNr := FindLine('Ordina risultati per', Page, 0);
  if LineNr = -1 then
//fulvio
    AnalyzeMoviePage(Page);
    campo_ricerca := getfield(fieldFilePath);
    if  campo_ricerca = '' then
        campo_ricerca := getfield(fieldFormattedTitle);
    PickTreeAdd('Risultati ricerca per "' + campo_ricerca + '":', '');                                               // per più pagine di film
    AddMoviesTitles;
    if TheMovieAddress='' then
	 AnalyzePage(Address);
  Line, PreviousLine, Save_line, NomeHtml, sTemp: string;
  AddrImage: string;
  LineNr,PrevLineNr, BeginPos, EndPos, Field: Integer;
  IsMainActors: boolean;
  IsMainActors := false;
  sTemp := '';
//  SetField(fieldURL, Address);
  LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
  if LineNr = -1 then        //2018.05.05
    LineNr := FindLine('<font face="arial, helvetica" size="2"><b>', Page, 0);       //2018.05.05
  if LineNr > -1 then
    //Translated Title
    HTMLRemoveTags(Line);
//fs    SetField(fieldTranslatedTitle, Line);
    save_translated :=  AnsiMixedCase(AnsiLowerCase(Line), ' ');
    Save_translated := RemoveHtmlClean(Save_translated);
    SetField(fieldTranslatedTitle, save_translated);
      //Look for next info
        LineNr := LineNr + 1;
      until (Line<>'')  or (LineNr > Page.Count);
      // Test if 'Trama:' missing
      if ((PreviousLine = 'Data di uscita:&nbsp;')
      or  (PreviousLine = 'Uscita prevista:&nbsp;')) and (Line <> 'Trama:') then
        if (copy(Line,1,6)<>'Trama:') then
          Line := 'Trama:' + Line;
      PreviousLine := Line;
      //Look for type of line
      if Line = 'Titolo originale:&nbsp;' then
        Field := fieldOriginalTitle
      else if Line = 'Regia:&nbsp;' then
        Field := fieldDirector
      else if Line = 'Produzione:&nbsp;' then
        Field := fieldProducer
      else if Line = 'Nazione:&nbsp;' then
        Field := fieldCountry
      else if Line = 'Genere:&nbsp;' then
        Field := fieldCategory
      else if Line = 'Anno:&nbsp;' then
        Field := fieldYear
      else if Line = 'Durata:&nbsp;' then
        Field := fieldLength //Special case: get number only
      else if Line = 'Sito ufficiale:&nbsp;' then
        Field := fieldURL
      else if Line = 'Attori protagonisti:&nbsp;' then
        Field := fieldActors;
        IsMainActors := true;
      else if Line = 'Cast:&nbsp;' then
      else if Line = 'Trama:' then
        Field := fieldDescription          //2018.04.30fs
            DumpPage(folder + 'FilmUP_line' + IntToStr(ctr_giri) + '.txt', Blocco);                // debug
        Field := 0;
      // I have to add this test, for sometimes the description
      // is on the same line as the tag 'Trama'
      if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
             DumpPage(folder + 'FilmUP_page2.txt', pagestr);                //2018.04.30fs
         Field := fieldDescription;
         Line := Textbetween(Pagestr, 'Trama:<br>', '</font>');
             DumpPage(folder + 'FilmUP_line_trama.txt', Line);                // debug
         HTMLDecode(Line);                    //2018.04.30fs
        //Get values
        HTMLDecode(Line);
        //Special case: Length
        if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
       //Alternative URL case
       if (field = fieldURL) then
         if (Length(Line) = 0) or (GetOption('AlternateURL')=0) then      // if WEB url missing or explicitly requested...
           Line := GetField(fieldURL)  // ...restore FilmUp URL
           Line := 'http://'+Line;
      if Field<>0 then
       if Field = fieldActors then
         if IsMainActors then // Remember Main Actors (if present)
           sTemp := Line;
           if ((GetOption('ActorsPlusCast')=1) and (sTemp<>'')) then
             Line := sTemp + ' Cast: ' + Line
             if sTemp <> '' then
               Line := sTemp;
           Line := UTF8decode(Line);         //2018.04.30fs
           SetField(Field,Line);
         if field = 25 then             //2018.05.05fs        field 25 è fielddescription
            save_line := Line;          //2018.05.05fs
            if Line = '' then       //2018.05.05fs
               Line := save_line;                      //2018.05.05fs
    until (Field=fieldDescription) or (LineNr > Page.Count);
    Save_original := getfield(fieldOriginalTitle);
    Save_original := RemoveHtmlClean(Save_original);
    if AnsiLowerCase(Save_translated) = AnsiLowerCase(Save_original) then
       setfield(FieldOriginalTitle, '');
  PrevLineNr := LineNr;
   //Trailer
if GetOption('TrailerURL')=1 then begin
LineNr := FindLine('">Trailer</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('size="2"><a', Line) <> 0 then Delete(Line,1,pos('size="2"><a',Line));
    //if Pos('DVD', Line) <> 0 then Delete(Line,1,pos('DVD',Line));
    Delete(Line,1,pos('href="',Line)+5);
    NomeHtml := Copy(Line,1,pos('"',Line)-1);
    if (copy(NomeHtml,1,1)<>'/') then
      NomeHtml := '/' + NomeHtml;
    NomeHtml :='http://filmup.leonardo.it' + NomeHtml;
    comm := textbetween(GetPage(NomeHtml),'<EMBED SRC="','"');
//HTMLRemoveTags(comm);
//Fulvio  SetField(fieldURL,comm);
  //Comments
  LineNr := FindLine('">Recensione</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('Scheda', Line) <> 0 then
      Delete(Line,1,pos('Scheda',Line));
    NomeHtml :=Copy(Line,1,pos('"',Line)-1);
    SaveComm := '';
    SaveComm := GetPage(NomeHtml);
//    SaveComm := UTF8decode(SaveComm);
       DumpPage(folder + 'comments.txt', SaveComm);                //2018.04.30fs
    comm := textbetween(SaveComm,'<font face="arial,helvetica" size="2"><b>','<a class="filmup" href="opinioni.htm">');    //vecchio formato
    if  length(comm) < 1 then
      comm := textbetween(SaveComm,'<div class="testo-articolo">','</div>');      //2018.05.05 nuovo formato
      comm := textbetween(SaveComm,'<td width="100%" valign="top"><font size="3"><b>','<a class="filmup" href="opinioni.htm">');      //nuovo formato
//    comm := TextAfter(comm,'</b><br>'+#13#10);
    Comm := RemoveHtmlClean(Comm);
    Comm := stringreplace(Comm, accento, apice);                 //2018.04.30fs
    comm := DecodePage(comm);                //2018.04.30fs      qui da correggere ?  in apostrofi
    SetField(fieldComments,comm);
  //Rating
  LineNr := FindLine('">Opinioni</a>', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('Recensione',Line));
    Line := GetLineFromOtherPage(Copy(Line,1,pos('"',Line)-1),'</b> - <img src="');
    if Line <> '' then
      Line := Copy(Line,1,pos('</b> - <img src="',Line)-1);
      if GetOption('MezzoVoto')=0 then
 if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
      SetField(fieldRating,Line);
  //Picture // start fulvio53s03 Code
    LineNr := FindLine('<img src="locand/', Page, PrevLineNr);
  if LineNr > -1 then
      AddrImage := TextBetween(Line, '<img src="', '" width="');
      AddrImage := 'http://filmup.leonardo.it/' + AddrImage;
      GetPicture(AddrImage);
  if GetOption('Poster')=1 then
    LineNr := FindLine('href="posters/locp/', Page, PrevLineNr);  //cerca Poster grande
    if LineNr > -1 then
      AddrImage := TextBetween(Line, 'href="posters/locp/', '" target="_blank"');
      AddrImage := 'http://filmup.leonardo.it/posters/loc/500/' + AddrImage;
      AddrImage := StringReplace(AddrImage, '.htm', '.jpg');
//      http://filmup.leonardo.it/posters/locp/toystory2.htm
//      http://filmup.leonardo.it/posters/loc/500/toystory2.jpg
//      Line := GetLineFromOtherPage('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
//      if Line <> '' then
//      begin
//        Delete(Line,1,pos('<img src="../',Line)+12);
//        GetPicture('http://filmup.leonardo.it/posters/'+Copy(Line,1,pos('"',Line)-1));
//      end;
function RemoveHtmlClean(str1: string) :string;
  HTMLRemoveTags(str1);
  HTMLDecode(str1);
//  str1 := RemoveTabs(str1);
  result := FullTrim(str1);
function RemoveTabs(Pattern: string): string;
  Delete(Pattern, 1, 1);
  until ord(copy(Pattern, 1, 1)) <> 9;
  result := Pattern;
function GetLineFromOtherPage(address: string; hint: string): string;
  LineNr: integer;
  LineNr := FindLine(hint, Page, 0);
  if LineNr > -1 then result := Page.GetString(LineNr);
procedure GetComments(address: string);
  BeginLine: integer;
  EndLine: integer;
  i: integer;
  Line, Comments: string;
  BeginLine := FindLine('RECENSIONI', Page, 0);
  BeginLine := FindLine('<font face="arial,helvetica" size="2"><b>', Page, BeginLine);
  EndLine := FindLine('<a href="opinioni.htm">Scrivi la tua recensione!</a></font><br><br>', Page, BeginLine);
  for i:= BeginLine+1 to EndLine-1 do
    Line := Page.GetString(i);
    Line := StringReplace(Line, '<br>', #13#10);
    Line := StringReplace(Line, #13#10#32, #13#10);
    HTMLDecode(Line);
    Comments := Comments + Line;
  comments := Utf8decode(comments);          //2018.04.30fs
function MyTrim(Value: string):string;
  ExitLoop: Boolean;
  NewField, OldField: String;
  OldLgthValue, NewLgthValue: integer;
    NewField := ' ';
    OldField := #9;
    value := StringReplace(Value, OldField, NewField);
    OldField := #10;
    OldField := #13;
    OldField := '  ';
    Newfield := '&';
    OldField := '&';
    ExitLoop := False;
    OldLgthValue := length(Value);
      NewLgthValue := length(Value);
    if  OldLgthValue = NewLgthValue then
        ExitLoop := True
        OldLgthValue := NewLgthValue;
    until ExitLoop;
  Result := '';
  HTMLRemoveTags(Value);
  Result := Value;
procedure AddMoviesTitles;
  LineNr, CharToDelete: Integer;
  Line, Blocco: string;
  MovieAddress, MovieAnno: string;
  BeginPos, EndPos, ctr_giri: Integer;
//fulvio  LineNr := FindLine('FilmUP - Scheda: ',Page,LineNr);
  ctr_giri := 0;
  Pagestr := '<DL>' + Textbetween(Pagestr, '<DL>', 'Risultati della ricerca:<br>');     //estrae tabella dei risultati
  Blocco := Textbetween(Pagestr, '<DL>', '</DL>');         //estrae elemento della tabella
  CharToDelete := Length(Blocco) + 9;    //lgth dati estratti + lgth delimiters estrazione
  while CharToDelete > 9 do
    MovieAddress := TextBetween(Blocco, '<a class="filmup" href="', '" TARGET="_blank">');
//2018.04.27    MovieTitle := TextBetween(Blocco, 'FilmUP - Scheda: ', '</a>');
    MovieTitle := TextBetween(Blocco, 'TARGET="_blank">', '</a>');              //2018.04.27
    MovieTitle := stringReplace (MovieTitle,+ 'FilmUP - Scheda: ', '');         //2018.04.27
    MovieTitle := Mytrim(MovieTitle);
//    HTMLRemoveTags(MovieTitle);
//    HTMLDecode(Movietitle);
//**************    //fs da verificare
    MovieAnno := TextBetween(Blocco, 'Anno: ', ' Genere');
    MovieTitle := MovieTitle + ' [' + MovieAnno + ']';
    HTMLDecode(MovieTitle);
    MovieTitle := StringReplace(MovieTitle, ' - FilmUP.com ', '');
    lgth_title := length(MovieTitle);
//2018.04.27    If (lgth_title > 3) and (pos(MovieAddress, '/soundtrack/') > 0) then
    If (lgth_title > 3) and (pos('/soundtrack/', MovieAddress) = 0) then
    if TheMovieAddress='*' then
       TheMovieAddress := MovieAddress
       TheMovieAddress := '';
    delete(Pagestr, 1, CharTodelete)
    ctr_giri := ctr_giri + 1;
//    delete(Pagestr, 1, CharTodelete)
//  end;
//Fulvio  LineNr := FindLine('Successivo',Page,LineNr);
//Fulvio  Line := Page.GetString(LineNr);
//Fulvio  BeginPos := pos('HREF',Line);
//Fulvio  if BeginPos>0 then
//Fulvio  begin
//Fulvio    Delete(Line,1,BeginPos + 5);
//Fulvio    EndPos := pos('"',Line);
//Fulvio    MovieAddress := copy(Line,1,EndPos-1);
//Fulvio    PickTreeMoreLink(MovieAddress);
//Fulvio  end;
// Questo è il main dello script
  if CheckVersion(3,5,0) then
    TheMovieAddress := '*';
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
    if Input('FilmUP Import', 'Digita il titolo del film:', MovieName) then
    MovieToSearch:=StringReplace(MovieName, ' ', '+');
//Fulvio  ricerca per 'Termini contenuti':
// &ul=%25%2Fsc_%25&x=60&y=11&m=all&wf=0020&wm=sub&sy=0
    Pagina_Ricerca := 'http://filmup.leonardo.it/cgi-bin/search.cgi?ps=100&fmt=long&q='+MovieToSearch+'&ul=%25%2Fsc_%25&x=60&y=11&m=all&wf=0020&wm=sub&sy=0';
    AnalyzePage(Pagina_Ricerca);
//Fulvio  ricerca per 'Termini esatti':
//    AnalyzePage('http://filmup.leonardo.it/cgi-bin/search.cgi?ps=100&fmt=long&q='+MovieToSearch+'&ul=%25%2Fsc_%25&x=31&y=12&m=all&wf=0020&wm=wrd&sy=0');
    ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.5.0)');
Implementazione dell'estrazione di descrizioni e commenti.
Estrazione del voto (quando presente).
Implementation of the extraction of descriptions and comments.
Rating extraction (when present).
Re: [ITA] FilmUp.it updated
otreux
Post by otreux »
Grazie! Sopratutto per l'inserimento dei voti che sono utilissimi quando si ha voglia di vedere un film nuovo e non si ha voglia di cercare in rete i feedback
Thank you! Especially for the inclusion of votes that are very useful when you want to see a new film and do not want to search the network for feedback
Ho fatto una prova, ho scaricato la scheda di Magnolia.
Mi ha scaricato solo le tre righe di descrizione scritte nella pagina iniziale. Col tuo script è possibile fargli scaricare il contenuto del link "Recensione" e metterlo nel campo "Commenti" di AMC? O, eventualmente, il contenuto delle Opinioni.
Potresti fare in modo che lo script scarichi sempre il voto, se presente. Altrimenti tutte le volte ci si deve ricordare di spuntare il campo.
Ultima cosa, nel caso di Magnolia che non ha la locandina grande, non sarebbe meglio fargli scaricare almeno quella piccola?
Grazie ancora
I took a test, I downloaded the Magnolia card.
He only downloaded the three lines of description written on the home page. With your script can you let him download the contents of the "Review" link in the "Comments" field of AMC? Or, possibly, the content of Opinions.
You could make the script always download the vote, if any. Otherwise, every time you have to remember to check the field.
Last thing, in the case of Magnolia that does not have the big poster, it would be better to let him download at least that little one?
Thanks again
otreux
Post by otreux »
Per "Pronti a morire" lo script mi da error in expression linea 134
otreux wrote: 2018-05-07 10:24:24 Per "Pronti a morire" lo script mi da error in expression linea 134
Filmup mostra degli errori in qualche percorso.
Mi ci dedicherò.
Sorry, Filmup shows errors in some paths.
I'll take a look.
otreux
Post by otreux »
Grazie, anche nel post precedente ho segnalato alcune imperfezioni. In ogni caso lo script funziona già egregiamente e te ne siamo tutti grati :clapping:
Thanks, even in the previous post I reported some imperfections. In any case, the script already works very well and we are all grateful :clapping:
otreux
Post by otreux »
io se trovo delle anomalie te le segnalo, poi vedi tu se è il caso di intervenire.
Mi sono accorto che di alcuni film non scarica il voto neanche se si spunta la voce. Ad esempio "La mia migliore nemica"
If I find anomalies I'll point them out, then you see if it's appropriate to intervene.
I realized that some movies do not download the vote even if the voice appears. For example "My best enemy"
Thanks!
otreux wrote: 2018-05-08 17:08:40 io se trovo delle anomalie te le segnalo, poi vedi tu se è il caso di intervenire.
Thanks!
Certo, è così che si fa. Molti siti sono stratificazioni storiche fatte da autori diversi e secondo standard vari.
Per adeguare lo script è necessario avere l'indicazione del titolo in cui l'anomalia si verifica.
C'è un po' di confusione tra filmup e filmTV, mi pare.... in filmup il voto è nelle "opinioni", pagina che fin'ora non è mai stata considerata.
qui parliamo di filmup, per FilmTV apri un altro topic, per favore.
otreux
Post by otreux »
non ho capito. Io ricordo che era solo Filmup che permetteva di estrarre i voti, ed in effetti in questo thread che parla di Filmup tu scrivi "Estrazione del voto (quando presente)." Non capisco
