FilmAffinity 3.03 no funciona
masterchipo
Post by masterchipo »
Hola amigos el script nuevo de FilmAffinity 3.03 no funciona.
No importa ni título original, ni país, ni compositor, ni categoría, ni año, ni puntaje ni duración ni extras ni comentarios.
En síntesis funcionaba mejor el 3.02 que este
Re: FilmAffinity 3.03 no funciona
Someone else reported similar problem:
viewtopic.php?p=43203#p43203
but for me and most of the other users it seems to work fine.
However maybe it depends on the movie... can you post an example of a movie page that has more details than what is imported?
masterchipo
antp wrote: 2018-04-18 17:06:54 Someone else reported similar problem:
Ejemplos: Deliverance (1972)
Den of Thieves (2018)
The Last Movie Star (2017)
En fin todas. He probado con todas y esos campos quedan en blanco o no se importan
Gracias
Examples: Deliverance (1972)
In order all. I've tried with all of them and those fields are left blank or they do not matter
Thank you
Attention, what does not work is script 3.03, which I updated today. The 3.02 worked well for me as the new AMC beta.
Atención, lo que no funciona es el script 3.03, que he actualizado el día de hoy. El 3.02 a mí me funcionaba bien como el nuevo beta de AMC
First one does not seem to exist
The two others work fine for me... weird :/
masterchipo
antp wrote: 2018-04-18 17:20:19 First one does not seem to exist
It's very weird. I just updated the FilmAfttinity script from 3.0.2 to 3.0.3. of the AMC version 4.2.2 beta, also updated. And it is this (the 3.0.3) that has these errors
Es muy raro. Yo solo actualicé el script de FilmAfttinity del 3.0.2 al 3.0.3. de la versión AMC 4.2.2 beta, también actualizado. Y es este (el 3.0.3) el que tiene estos errores
Gracias
Only difference between 3.0.2 and 3.0.3 is how the title is encoded when doing the search (for the accents)
All what happens after the initial search is identical.
If there are differences that comes either from the AMC Version 4.2.1 vs 4.2.2 or the site itself.
masterchipo
antp wrote: 2018-04-18 21:19:39 Only difference between 3.0.2 and 3.0.3 is how the title is encoded when doing the search (for the accents)
Dear antp, I do not know what the problem is. I only know that with the new version of AMC and 3.0.2 it worked and just today I updated the script and the most important fields did not work or stopped working.
Estimado antp, yo no sé cuál es el problema. Solo sé que con la versión nueva de AMC y el 3.0.2 funcionaba y justo hoy actualicé el script y los campos más importantes no funcionaban o dejaron de funcionar
masterchipo
My friend antp, I searched the AMC file, the FilmAffinity scripts, I downloaded the one I had, I deleted the script 3.0.3 installed in the program. I deleted it. I downloaded the one in the file and replaced it with the one that was installed in the automatic update. Now it works normally :clapping:
http://update.antp.be/amc/scripts/archive/
amigo antp, busqué en el archivo de AMC, los scripts de FilmAffinity, descargué el que había, borré el script 3.0.3 instalado en el programa. Lo eliminé. Bajé el que está en el archivo y lo reemplacé por el que estaba instalado de la actualización automática. Ahora funciona normalmente
De este link lo bajé
Gracias
